@Bulldoglowell
Sorry man, If I saw those in a low voltage cabinet, I’d go find my gun! If any of my techs even had those in their toolbox, they would be fired on the spot!
Here is how I use terminal blocks. The right side shows the power wires coming in. Each block is + or -.
You can also just get a block with all terminals joined, so no need to make jumpers. I happen to have these in stock, so I used them.
@Bucko, thank you for that picture. I honestly couldn’t figure out why so many terminals didn’t have the bus bar like this one:
I now realize that using the jumpers is key to using terminal blocks. Seems like more would have the bus bar, but I could only find the uncovered one above.
@Z-Waver
" You can get blocks with the jumpers already in place, but I can’t find a source on Amazon at the moment."
That was my problem so I had to make do. However, the next time I’m in Shenzhen blocks are on my short list. Those DSC’s look good. When I find in Shenzhen, they would cost me about $1 each.
@ S-F
That is Shenzhen China where 90% of all electronics are manufactured. (I live in China).
@ jimpapa
Yep, the best way to go I think. Also makes rebooting cams a breeze as well. In fact I use two of these cans and power relays, screamers, sirens, pir’s and what have you. These cans cost me about $15 here.
@ z-waver
TU. LOL about the Poe. I originally thought about using them, but I’m actually old school. Plus I found that Poe switchers run too hot for my likening. Ain’t no big thing to run 18/2 anyways. Plus you get lots of cool lights. haha
I’m not following you there. So run power to one or two and then make little jumpers to connect the other six or seven?
The local RadioShack has these for about $2.5 so I’d like to use them.[/quote]
Sorry for the delay, my in-laws arrived on Tuesday so been flat out. Looks like you’ve worked out what I meant, and others have presented alternatives in the meantime… I like the shielded variant.
