I have some scenes to control my shades (Somfy RTS with Telis 4). So I have to simulate the channel change by switching on and of a specific amount of times.
This works but I wanted to optimize a little bit and now the code doesn’t work anymore. But I have absolutely no clue why. I didn’t even change anything where the error occurs.
Please find the code attached.
Thanks for any help, this issue was eating up hours already…
Yes the problem was, that I couldn’t trigger with its state otherwise if it was already on. So if choose UP but the shades have been closed by the scene “Close All Shades”, it wouldn’t trigger.
In functions reset_channel_on_Open and channel_on_Open, you have an argument that you test and decrement. If the value was > 0, you call a different function and don’t include the argument. I cannot believe that is what you intended…
I use global variables without passing it. As far as I understand it this should be no problem.
At first I reset the variable and work with it during the scene. After this I don’t use it anymore, unless I restart the scene and overwrite it with the initial value.
In the end it works now. Just some issues with the timing to iron out.
