I’ve seen several ask about support for rtsp cameras in the video sub-forum but didn’t see an official answer. So I’m posting here.
I have 2 cameras with HTTP based streams and 2 with rtsp streams. The http streams are a no-brainer but can’t get the rtsp camera streams to work. Does Vera support rtsp cameras (I’m using a VeraSecure) without having to use in intermediary?
RTSP support is there but it’s not global. It’s only implemented for Vistacam cameras.
Instead of individually working for each of the third party cameras, R&D is considering and analyzing implementation of ONVIF , for broader camera support.
[quote=“John M., post:6, topic:196897”]RTSP support is there but it’s not global. It’s only implemented for Vistacam cameras.
Instead of individually working for each of the third party cameras, R&D is considering and analyzing implementation of ONVIF , for broader camera support.[/quote]
Thank you very much for your response! I too will cast my vote for ONVIF as all my cameras fully support the protocol. Now I will get to work hacking the Vistacam implementations to see if I can finagle one to work with a batch of camera’s from China. Using URLHelper I discovered the following rstp feed on the cameras:
