RoomMe - Presence Detector
I’m tracking people, and I save their location (in my case, home, office, elsewhere) to trigger different actions (and adapt, ie when transitioning from home to elsewhere, then office).
All that said, it really depends on what you’d like to achieve.
I’m getting close to finishing my RoomMe plugin, but I’m no longer seeing log entries come in, I seem to be getting more of the following instead…
02	08/29/21 11:04:28.202	UserData::TempLogFileSystemFailure start 0 <0x76dae520>
02	08/29/21 11:04:28.230	UserData::TempLogFileSystemFailure (not failure, only WriteUserData) 0 <0x76dae520>
Is this related ? If so is there anything I can do ?
I’m trying to troubleshoot some things, and could do with seeing the log entries coming in…
UPDATE : I’m also noticing the following in the logs too, shortly before the above TempLogFileSystemFailure messages…
02	08/29/21 16:04:28.146	UserData::CommitToDatabase data size 58810 58810 <0x76dae520>
01	08/29/21 16:04:28.166	UserData::WriteUserData saved--before move File Size: 16558 save size 16558 <0x76dae520>
Coincidence ? - I’m guessing related - perhaps resource constraints?
Here’s the full related section from my log…
02	08/29/21 16:28:28.148	UserData::CommitToDatabase data size 58808 58808 <0x76dae520>
01	08/29/21 16:28:28.167	UserData::WriteUserData saved--before move File Size: 16580 save size 16580 <0x76dae520>
02	08/29/21 16:28:28.168	UserData::TempLogFileSystemFailure start 0 <0x76dae520>
02	08/29/21 16:28:28.182	UserData::TempLogFileSystemFailure (not failure, only WriteUserData) 0 <0x76dae520>
02	08/29/21 16:28:28.183	<0x1b>[33;1mUserData::TempLogFileSystemFailure 699 res:1
-rw-r--r--    1 root     root           504 Dec  4  2019 /etc/cmh/user_data.json.luup.lzo
-rw-r--r--    1 root     root         16564 Aug 29 16:10 /etc/cmh/user_data.json.lzo
-rw-r--r--    1 root     root         16558 Aug 29 16:04 /etc/cmh/user_data.json.lzo.1
-rw-r--r--    1 root     root         16586 Aug 29 15:58 /etc/cmh/user_data.json.lzo.2
-rw-r--r--    1 root     root         16587 Aug 29 15:46 /etc/cmh/user_data.json.lzo.3
-rw-r--r--    1 root     root         16599 Aug 29 15:40 /etc/cmh/user_data.json.lzo.4
-rw-r--r--    1 root     root         16592 Aug 29 15:28 /etc/cmh/user_data.json.lzo.5
-rw-r--r--    1 root     root         16580 Aug 29 16:28 /etc/cmh/user_data.json.lzo.new
<0x1b>[0m <0x76dae520>
02	08/29/21 16:28:28.244	UserData::TempLogFileSystemFailure start 0 <0x76dae520>
02	08/29/21 16:28:28.259	UserData::TempLogFileSystemFailure (not failure, only WriteUserData) 0 <0x76dae520>
02	08/29/21 16:28:28.260	<0x1b>[33;1mUserData::TempLogFileSystemFailure 610 res:1
-rw-r--r--    1 root     root         16564 Aug 29 16:10 /etc/cmh/user_data.json.lzo.1
-rw-r--r--    1 root     root         16558 Aug 29 16:04 /etc/cmh/user_data.json.lzo.2
-rw-r--r--    1 root     root         16586 Aug 29 15:58 /etc/cmh/user_data.json.lzo.3
-rw-r--r--    1 root     root         16587 Aug 29 15:46 /etc/cmh/user_data.json.lzo.4
-rw-r--r--    1 root     root         16599 Aug 29 15:40 /etc/cmh/user_data.json.lzo.5
UPDATE : Came across this on another post, which looks related, although no clear cause/fix
