Trying to setup Roomieremote but cannot seem to find my Vera Plus as a device - does anybody know how to setup Vera on Roomie Remote (have tried some of the older posts but cant seem to get it…)
When the new Roomie Remote looks for devices, it will auto discover your Vera Controller IF it’s on the same sub-net. You can also manually enter the Vera’s IP address into Roomie… But first, make sure your Vera has a static IP. address.
Hopefully you gave your Roomie Remote the right to discover all devices on your local network. All the new apps ask for this permission the first time you run the app.
Once Roomie can detect the Vera, you can add lights, etc. The lights will all have different numbers.
