My Vera Lite hasn’t even arrived yet bu I have a Rocki device ready and waiting so hopefully it works as a playback device :-)… Will update this topic once I find out.
[quote=“tommysharp, post:1, topic:181503”]My Vera Lite hasn’t even arrived yet bu I have a Rocki device ready and waiting so hopefully it works as a playback device :-)… Will update this topic once I find out.
Are you sure that it is a UPnP AV / DLNA device ?
They don’t have much info on their website but got this from the Kickstarter page…
“Supports UPnP / DLNA, compatible with existing open standards systems”
They say it can even be configured as the “sound card” on a PC using a special driver and then all your PC sounds will be played through it.
I’m secretly hoping it’s a nice cheap way to achieve Sonos like functionality.
Is there an easy way I can test it without having my Vera yet?
I have a ROCKI in my setup and can use the plugin to control when it is actively playing (pause, volume, etc).
It however does not display what is playing (don’t know if it should) and it always says “Playing” even if something is not.
The TTS feature worked once…however I can’t get it to do it again ???
Did you install the plugin UPnP event proxy ?
It looks like event notification is not received or inappropriate.
If UPnP event proxy is working well, please enable debug logs and provide these logs.
I don’t know what that is…so probably not ;D
I will start poking around for some more info on it and install it.
Alrighty, installed the plugin…restarted…and rebooted. Doesn’t seem to have any impact.
Si I need debug logs.
I apologize for my ignorance in advance, how do I send debug logs for the app?
I apologize for my ignorance in advance, how do I send debug logs for the app?[/quote]
Go in the advanced tab and set variable DebugLogs to 1 and then save (reload).
Play a little with your ROCKI and see if something is wrong (errors) in the logs (of course in particular lines containing string DLNA).
What could be interesting for me is in particular all lines containing the string handleAVTransportChange because it includes all the XML data sent by your ROCKI to the plugin.
If you want to send me a full file of logs, send me a PM to get an e-mail.
[quote=“lolodomo, post:10, topic:181503”]Go in the advanced tab and set variable DebugLogs to 1 and then save (reload).
If you want to send me a full file of logs, send me a PM to get an e-mail.[/quote]
@lolodomo - i just got a Rocki and have started testing. When i use TTS from UI5 it does not say all the words. For example, if i put “this is a test of the system” (no quotes) into the Text box and click say, it only says “this is a test”. If i put “this is a test of the system 1 2 3” into the Text box it says “this is a test of the system 1”. It I put “this is a test of the system broadcasting” into the text box, it says “this is a test of the system br”
Here is a debug log. Is there anything i can do to help figure out the issue? Thanks !
# tail -f /var/log/cmh/LuaUPnP.log | grep DLNA
08 05/31/14 16:23:51.910 JobHandler_LuaUPnP::HandleActionRequest device: 214 service: urn:dlna-org:serviceId:DLNAMediaController1 action: Say <0x322ae680>
08 05/31/14 16:23:51.911 JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:dlna-org:serviceId:DLNAMediaController1 <0x322ae680>
50 05/31/14 16:23:51.924 luup_log:214: DLNA: debug: TTS queueAlert for device 214 <0x322ae680>
50 05/31/14 16:23:51.924 luup_log:214: DLNA: debug: Google TTS: device 214 language en <0x322ae680>
50 05/31/14 16:23:52.482 luup_log:214: DLNA: debug: savePlaybackContext: start <0x322ae680>
50 05/31/14 16:23:52.482 luup_log:214: DLNA: debug: refreshNow: start <0x322ae680>
50 05/31/14 16:23:52.483 luup_log:214: DLNA: debug: GetTransportInfo('http://192.168.1.48:49153/upnp/control/rendertransport1', 'urn:schemas-upnp-org:service:AVTransport:1') Called with parameter count=1 <0x322ae680>
50 05/31/14 16:23:52.484 luup_log:214: DLNA: debug: UPnP_request: url=[http://192.168.1.48:49153/upnp/control/rendertransport1], body=[<?xml version="1.0" encoding="utf-8"?>
50 05/31/14 16:23:52.516 luup_log:214: DLNA: debug: UPnP_request: status=1 statusMsg=200 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body>
50 05/31/14 16:23:52.518 luup_log:214: DLNA: debug: GetTransportSettings('http://192.168.1.48:49153/upnp/control/rendertransport1', 'urn:schemas-upnp-org:service:AVTransport:1') Called with parameter count=1 <0x322ae680>
50 05/31/14 16:23:52.519 luup_log:214: DLNA: debug: UPnP_request: url=[http://192.168.1.48:49153/upnp/control/rendertransport1], body=[<?xml version="1.0" encoding="utf-8"?>
50 05/31/14 16:23:52.548 luup_log:214: DLNA: debug: UPnP_request: status=1 statusMsg=200 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body>
50 05/31/14 16:23:52.549 luup_log:214: DLNA: debug: GetCurrentTransportActions('http://192.168.1.48:49153/upnp/control/rendertransport1', 'urn:schemas-upnp-org:service:AVTransport:1') Called with parameter count=1 <0x322ae680>
50 05/31/14 16:23:52.550 luup_log:214: DLNA: debug: UPnP_request: url=[http://192.168.1.48:49153/upnp/control/rendertransport1], body=[<?xml version="1.0" encoding="utf-8"?>
50 05/31/14 16:23:52.582 luup_log:214: DLNA: debug: UPnP_request: status=1 statusMsg=200 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body>
50 05/31/14 16:23:52.583 luup_log:214: DLNA: debug: GetMediaInfo('http://192.168.1.48:49153/upnp/control/rendertransport1', 'urn:schemas-upnp-org:service:AVTransport:1') Called with parameter count=1 <0x322ae680>
50 05/31/14 16:23:52.584 luup_log:214: DLNA: debug: UPnP_request: url=[http://192.168.1.48:49153/upnp/control/rendertransport1], body=[<?xml version="1.0" encoding="utf-8"?>
08 05/31/14 16:23:52.600 JobHandler_LuaUPnP::HandleActionRequest device: 214 service: urn:dlna-org:serviceId:DLNAMediaController1 action: NotifyAVTransportChange <0x32cae680>
08 05/31/14 16:23:52.601 JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:dlna-org:serviceId:DLNAMediaController1 <0x32cae680>
50 05/31/14 16:23:52.623 luup_log:214: DLNA: debug: UPnP_request: status=1 statusMsg=200 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body>
50 05/31/14 16:23:52.626 luup_log:214: DLNA: debug: GetPositionInfo('http://192.168.1.48:49153/upnp/control/rendertransport1', 'urn:schemas-upnp-org:service:AVTransport:1') Called with parameter count=1 <0x322ae680>
50 05/31/14 16:23:52.630 luup_log:214: DLNA: debug: UPnP_request: url=[http://192.168.1.48:49153/upnp/control/rendertransport1], body=[<?xml version="1.0" encoding="utf-8"?>
50 05/31/14 16:23:52.662 luup_log:214: DLNA: debug: UPnP_request: status=1 statusMsg=200 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body>
50 05/31/14 16:23:52.688 luup_log:214: DLNA: debug: GetMute('http://192.168.1.48:49153/upnp/control/rendercontrol1', 'urn:schemas-upnp-org:service:RenderingControl:1') Called with parameter count=1 <0x322ae680>
50 05/31/14 16:23:52.689 luup_log:214: DLNA: debug: UPnP_request: url=[http://192.168.1.48:49153/upnp/control/rendercontrol1], body=[<?xml version="1.0" encoding="utf-8"?>
50 05/31/14 16:23:52.722 luup_log:214: DLNA: debug: UPnP_request: status=1 statusMsg=200 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body>
50 05/31/14 16:23:52.723 luup_log:214: DLNA: debug: GetVolume('http://192.168.1.48:49153/upnp/control/rendercontrol1', 'urn:schemas-upnp-org:service:RenderingControl:1') Called with parameter count=1 <0x322ae680>
50 05/31/14 16:23:52.725 luup_log:214: DLNA: debug: UPnP_request: url=[http://192.168.1.48:49153/upnp/control/rendercontrol1], body=[<?xml version="1.0" encoding="utf-8"?>
50 05/31/14 16:23:52.747 luup_log:214: DLNA: debug: UPnP_request: status=1 statusMsg=200 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body>
50 05/31/14 16:23:52.749 luup_log:214: DLNA: debug: Stop('http://192.168.1.48:49153/upnp/control/rendertransport1', 'urn:schemas-upnp-org:service:AVTransport:1') Called with parameter count=1 <0x322ae680>
50 05/31/14 16:23:52.750 luup_log:214: DLNA: debug: UPnP_request: url=[http://192.168.1.48:49153/upnp/control/rendertransport1], body=[<?xml version="1.0" encoding="utf-8"?>
50 05/31/14 16:23:52.772 luup_log:214: DLNA: debug: UPnP_request: status=1 statusMsg=200 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body>
50 05/31/14 16:23:52.773 luup_log:214: DLNA: debug: SetAVTransportURI('http://192.168.1.48:49153/upnp/control/rendertransport1', 'urn:schemas-upnp-org:service:AVTransport:1') Called with parameter count=1 <0x322ae680>
50 05/31/14 16:23:52.775 luup_log:214: DLNA: debug: UPnP_request: url=[http://192.168.1.48:49153/upnp/control/rendertransport1], body=[<?xml version="1.0" encoding="utf-8"?>
50 05/31/14 16:23:52.930 luup_log:214: DLNA: debug: UPnP_request: status=1 statusMsg=200 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body>
50 05/31/14 16:23:52.932 luup_log:214: DLNA: debug: Play('http://192.168.1.48:49153/upnp/control/rendertransport1', 'urn:schemas-upnp-org:service:AVTransport:1') Called with parameter count=1 <0x322ae680>
50 05/31/14 16:23:52.934 luup_log:214: DLNA: debug: UPnP_request: url=[http://192.168.1.48:49153/upnp/control/rendertransport1], body=[<?xml version="1.0" encoding="utf-8"?>
50 05/31/14 16:23:53.218 luup_log:214: DLNA: debug: UPnP_request: status=1 statusMsg=200 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body>
50 05/31/14 16:23:53.219 luup_log:214: DLNA: debug: refreshNow: start <0x322ae680>
50 05/31/14 16:23:53.222 luup_log:214: DLNA: debug: handleAVTransportChange for device 214 value <Event xmlns = "urn:schemas-upnp-org:metadata-1-0/AVT/"><InstanceID val="0"><CurrentTransportActions val="Play"/></InstanceID></Event> <0x2b612000>
50 05/31/14 16:23:53.224 luup_log:214: DLNA: debug: GetPositionInfo('http://192.168.1.48:49153/upnp/control/rendertransport1', 'urn:schemas-upnp-org:service:AVTransport:1') Called with parameter count=1 <0x2b612000>
50 05/31/14 16:23:53.224 luup_log:214: DLNA: debug: UPnP_request: url=[http://192.168.1.48:49153/upnp/control/rendertransport1], body=[<?xml version="1.0" encoding="utf-8"?>
50 05/31/14 16:23:53.249 luup_log:214: DLNA: debug: UPnP_request: status=1 statusMsg=200 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body>
08 05/31/14 16:23:53.756 JobHandler_LuaUPnP::HandleActionRequest device: 214 service: urn:dlna-org:serviceId:DLNAMediaController1 action: NotifyAVTransportChange <0x336f0680>
08 05/31/14 16:23:53.757 JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:dlna-org:serviceId:DLNAMediaController1 <0x336f0680>
50 05/31/14 16:23:53.768 luup_log:214: DLNA: debug: handleAVTransportChange for device 214 value <Event xmlns = "urn:schemas-upnp-org:metadata-1-0/AVT/"><InstanceID val="0"><TransportState val="PLAYING"/></InstanceID></Event> <0x2b612000>
50 05/31/14 16:23:53.773 luup_log:214: DLNA: debug: GetPositionInfo('http://192.168.1.48:49153/upnp/control/rendertransport1', 'urn:schemas-upnp-org:service:AVTransport:1') Called with parameter count=1 <0x2b612000>
50 05/31/14 16:23:53.774 luup_log:214: DLNA: debug: UPnP_request: url=[http://192.168.1.48:49153/upnp/control/rendertransport1], body=[<?xml version="1.0" encoding="utf-8"?>
50 05/31/14 16:23:55.911 luup_log:214: DLNA: debug: UPnP_request: status=1 statusMsg=200 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body>
08 05/31/14 16:23:55.961 JobHandler_LuaUPnP::HandleActionRequest device: 214 service: urn:dlna-org:serviceId:DLNAMediaController1 action: NotifyAVTransportChange <0x334ae680>
08 05/31/14 16:23:55.962 JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:dlna-org:serviceId:DLNAMediaController1 <0x334ae680>
50 05/31/14 16:23:55.965 luup_log:214: DLNA: debug: handleAVTransportChange for device 214 value <Event xmlns = "urn:schemas-upnp-org:metadata-1-0/AVT/"><InstanceID val="0"><TransportState val="STOPPED"/></InstanceID></Event> <0x2b612000>
50 05/31/14 16:23:55.968 luup_log:214: DLNA: debug: GetPositionInfo('http://192.168.1.48:49153/upnp/control/rendertransport1', 'urn:schemas-upnp-org:service:AVTransport:1') Called with parameter count=1 <0x2b612000>
50 05/31/14 16:23:55.969 luup_log:214: DLNA: debug: UPnP_request: url=[http://192.168.1.48:49153/upnp/control/rendertransport1], body=[<?xml version="1.0" encoding="utf-8"?>
50 05/31/14 16:23:56.008 luup_log:214: DLNA: debug: UPnP_request: status=1 statusMsg=200 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body>
50 05/31/14 16:23:56.101 luup_log:214: DLNA: debug: TTS endPlayback for device 214 <0x31145680>
50 05/31/14 16:23:56.130 luup_log:214: DLNA: debug: restorePlaybackContext: start <0x31145680>
50 05/31/14 16:23:56.130 luup_log:214: DLNA: debug: Stop('http://192.168.1.48:49153/upnp/control/rendertransport1', 'urn:schemas-upnp-org:service:AVTransport:1') Called with parameter count=1 <0x31145680>
50 05/31/14 16:23:56.132 luup_log:214: DLNA: debug: UPnP_request: url=[http://192.168.1.48:49153/upnp/control/rendertransport1], body=[<?xml version="1.0" encoding="utf-8"?>
50 05/31/14 16:23:56.155 luup_log:214: DLNA: debug: UPnP_request: status=1 statusMsg=200 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body>
50 05/31/14 16:23:56.156 luup_log:214: DLNA: debug: SetMute('http://192.168.1.48:49153/upnp/control/rendercontrol1', 'urn:schemas-upnp-org:service:RenderingControl:1') Called with parameter count=1 <0x31145680>
50 05/31/14 16:23:56.157 luup_log:214: DLNA: debug: UPnP_request: url=[http://192.168.1.48:49153/upnp/control/rendercontrol1], body=[<?xml version="1.0" encoding="utf-8"?>
50 05/31/14 16:23:56.204 luup_log:214: DLNA: debug: UPnP_request: status=1 statusMsg=200 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body>
50 05/31/14 16:23:56.205 luup_log:214: DLNA: debug: SetVolume('http://192.168.1.48:49153/upnp/control/rendercontrol1', 'urn:schemas-upnp-org:service:RenderingControl:1') Called with parameter count=1 <0x31145680>
50 05/31/14 16:23:56.206 luup_log:214: DLNA: debug: UPnP_request: url=[http://192.168.1.48:49153/upnp/control/rendercontrol1], body=[<?xml version="1.0" encoding="utf-8"?>
08 05/31/14 16:23:56.220 JobHandler_LuaUPnP::HandleActionRequest device: 214 service: urn:dlna-org:serviceId:DLNAMediaController1 action: NotifyRenderingChange <0x336f0680>
08 05/31/14 16:23:56.221 JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:dlna-org:serviceId:DLNAMediaController1 <0x336f0680>
50 05/31/14 16:23:56.274 luup_log:214: DLNA: debug: UPnP_request: status=1 statusMsg=200 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body>
50 05/31/14 16:23:56.275 luup_log:214: DLNA: debug: SetAVTransportURI('http://192.168.1.48:49153/upnp/control/rendertransport1', 'urn:schemas-upnp-org:service:AVTransport:1') Called with parameter count=1 <0x31145680>
50 05/31/14 16:23:56.277 luup_log:214: DLNA: debug: UPnP_request: url=[http://192.168.1.48:49153/upnp/control/rendertransport1], body=[<?xml version="1.0" encoding="utf-8"?>
08 05/31/14 16:23:56.295 JobHandler_LuaUPnP::HandleActionRequest device: 214 service: urn:dlna-org:serviceId:DLNAMediaController1 action: NotifyRenderingChange <0x32cae680>
08 05/31/14 16:23:56.296 JobHandler_LuaUPnP::HandleActionRequest argument serviceId=urn:dlna-org:serviceId:DLNAMediaController1 <0x32cae680>
50 05/31/14 16:23:56.458 luup_log:214: DLNA: debug: UPnP_request: status=1 statusMsg=200 result=[<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body>
50 05/31/14 16:23:56.459 luup_log:214: DLNA: debug: refreshNow: start <0x31145680>
50 05/31/14 16:23:56.465 luup_log:214: DLNA: debug: handleRenderingChange for device 214 value <Event xmlns = "urn:schemas-upnp-org:metadata-1-0/RCS/"><InstanceID val="0"><Mute channel="Master" val="0"/><Volume channel="Master" val="80"/><PresetNameList val="FactoryDefaults"/></InstanceID></Event> <0x2b612000>
50 05/31/14 16:23:56.469 luup_log:214: DLNA: debug: handleRenderingChange for device 214 value <Event xmlns = "urn:schemas-upnp-org:metadata-1-0/RCS/"><InstanceID val="0"><Mute channel="Master" val="0"/><Volume channel="Master" val="80"/><PresetNameList val="FactoryDefaults"/></InstanceID></Event> <0x2b612000>
The Rocki probably takes more time as expected to start the playback and so the restore of the previous context occurs a little too early before the end of the file.
You can try to play with the variable DelayBeforePlayback you will find in the advanced tab. It is a value in milliseconds. Try to set it to 1000 for example.
[quote=“lolodomo, post:12, topic:181503”]The Rocki probably takes more time as expected to start the playback and so the restore of the previous context occurs a little too early before the end of the file.
You can try to play with the variable DelayBeforePlayback you will find in the advanced tab. It is a value in milliseconds. Try to set it to 1000 for example.[/quote]
Thanks @lolodomo - i tried that but it just delayed the start of the speech by that number of milliseconds. it still cut off in the middle of the sentence, at the same place, regardless of whether DelayBeforePlayback was 0, 1000, 3000, or 5000, it just started speaking after a longer delay with the higher value.
[quote=“mda, post:13, topic:181503”][quote=“lolodomo, post:12, topic:181503”]The Rocki probably takes more time as expected to start the playback and so the restore of the previous context occurs a little too early before the end of the file.
Thanks @lolodomo - i tried that but it just delayed the start of the speech by that number of milliseconds. it still cut off in the middle of the sentence, at the same place, regardless of whether DelayBeforePlayback was 0, 1000, 3000, or 5000, it just started speaking after a longer delay with the higher value.[/quote]
In this case, you can try to adjust in file L_DLNATTS.lua and function GoogleTTS the line (98):
duration = math.ceil(size/4000) + 1
replacing the final “+1” by “+2”. It will give one additional second for your file to be played.
[quote=“lolodomo, post:14, topic:181503”]In this case, you can try to adjust in file L_DLNATTS.lua and function GoogleTTS the line (98):
replacing the final “+1” by “+2”. It will give one additional second for your file to be played.[/quote]
@lolodomo i tried 2, 4, and 8 and it made no difference. i confirmed that my change was in place by re-downloading the file from vera. Using this phrase, it stops after the the word “come” regardless of the value in the .lua file.
luup.call_action("urn:dlna-org:serviceId:DLNAMediaController1", "Say", {Text="this is a test. Time for dinner everyone! please come to the table.", Language="en", Engine="GOOGLE", Volume=80}, 214)
Is there anything else i can try? Thanks.
[quote=“mda, post:15, topic:181503”][quote=“lolodomo, post:14, topic:181503”]In this case, you can try to adjust in file L_DLNATTS.lua and function GoogleTTS the line (98):
Is there anything else i can try? Thanks.[/quote]
In that case, it looks like a problem in the Rocki or the Rocki with the Vera WEB server.
To confirm that, you can try to retrieve the file generated by Google and play it with the Rocki by another way.
To retrieve the file, comment this line in function endPlayback:
os.execute(DELETE_EXECUTE:format(device))
After a new TTS try, you will find the MP3 file in directory /www with a name like Say.xx.mp3. The file is accessible through this URL too: http://:80/Say.xx.mp3
@lolodomo i followed your testing suggestion and i discovered that it cuts off even if a play it as an mp3 file. However, if i convert the mp3 file to a higher bitrate (at least 96k) then it plays the file all the way to the end !
I suppose that means the Rocki does not handle 16kbps mono mp3 files correctly? Is there any way the plugin could get the tts engine to generate a 96k mp3 file ? Thanks!
Bitrate is set by Google and cannot be changed, sorry.
Except this bug in Rocki causing a not perfect TTS, is everything else working well ?
I am just now starting to test other things on the rocki (I bought it for the purpose of tts). I was able to play an mp3 song (320kbps) on it fine, though I it did go “offline” a couple times yesterday in my testing requiring I re-discover it. I will let you know if that happens in normal use too when I am not doing the tts testing over the next few days.
