I’m looking in to using the Ring door sensors with the Ezlo Plus, since it’s a z-wave device. I have the device paired using the QR code scanning, but the Vera app shows nothing in terms of open or closed states, just battery level. The zwaved log shows the events from the sensor going apart/together. Do i need to do anything special to get this set up? Do i need to make my own lua script for this?
log entries:
Sensor going apart (Door open)
2022-01-19 18:55:45.090032 INFO : znetNodeCmdNotification Node ID: 2, v1 type: 0, type: 7, event: 2
Sensor coming back together (door closing)
2022-01-19 18:55:49.151651 INFO : znetNodeCmdNotification Node ID: 2, v1 type: 0, type: 7, event: 0
Cover off (tamper notice)
2022-01-19 18:58:06.340044 INFO : znetNodeCmdNotification Node ID: 2, v1 type: 0, type: 7, event: 3
2022-01-19 18:58:06.993654 INFO : znetWakeupNotification node: 2
2022-01-19 18:58:06.994025 INFO : requestNodeValues node 2
2022-01-19 18:58:06.994191 INFO : activateMode Current values
2022-01-19 18:58:06.994307 INFO : znet_smart_start_listen_mode_disable
2022-01-19 18:58:07.296937 INFO : znetMultichannelAssociationResult (node id: 2, channelId: 0, group id: 1)
2022-01-19 18:58:07.499714 INFO : znetNodeCmdConfiguration (node id: 2, channel id: 0, param: 1, value: 70)
2022-01-19 18:58:07.853276 INFO : znetNodeCmdConfiguration (node id: 2, channel id: 0, param: 2, value: 1)
2022-01-19 18:58:08.055708 INFO : znetNodeCmdConfiguration (node id: 2, channel id: 0, param: 3, value: 5)
2022-01-19 18:58:08.258029 INFO : znetNodeCmdConfiguration (node id: 2, channel id: 0, param: 4, value: 1)
2022-01-19 18:58:08.460569 INFO : znetNodeCmdConfiguration (node id: 2, channel id: 0, param: 5, value: 0)
2022-01-19 18:58:08.666495 INFO : znetNodeCmdConfiguration (node id: 2, channel id: 0, param: 6, value: 10000)
2022-01-19 18:58:08.869066 INFO : znetNodeCmdNotification Node ID: 2, v1 type: 0, type: 7, event: 0
2022-01-19 18:58:09.074239 INFO : znetNodeCmdNotification Node ID: 2, v1 type: 0, type: 8, event: 0
2022-01-19 18:58:09.278420 INFO : znetNodeCmdNotification Node ID: 2, v1 type: 0, type: 9, event: 0
2022-01-19 18:58:09.482551 INFO : znetNodeCmdBatteryLevel (node id: 2) value 100
2022-01-19 18:58:09.482842 INFO : onNodeCmdBatteryLevel battery level(100) for node Id = 2
2022-01-19 18:58:09.686457 INFO : znetWakeupResult node id: 2, value: 3600, target_node_id: 1
2022-01-19 18:58:09.686717 INFO : Cant handle node 2, use monitoring handler instead
2022-01-19 18:58:09.686874 INFO : activateMode Monitoring
2022-01-19 18:58:09.686989 INFO : znet_smart_start_listen_mode_enable
cover back on shows the same as door closed:
2022-01-19 19:02:40.706814 INFO : znetNodeCmdNotification Node ID: 2, v1 type: 0, type: 7, event: 0
