Hello,
I have a powermaxPro with Powerlink (that is functioning) I want to switch it with my Micasaverde Lite. Because I already have a part of the Visonic kit I tried to connect it to de Micasa with:
[ol][li]1. I bought a NMEA/RS232 to USB with FTDI chipset [url]http://www.pcnautic.nl/Com%20to%20USB%20RS232%20adapter%20naar%20USB[url]choose ftdi.
[/li]
[li]2. I already had a UTp to com cable which was used to configure a firewall (I think here it goes wrong.[/li][/ol]
I removed the powerlink from my visonic but enrollment of the “micasapowerlink” fails. I get a beeeeeeeeep in stead of a beep beep beep beeeep.
How can I check if my “UTP” to Com is right?
Where can I buy the right cable (prefered in a NL shop but not mandatory). Or does it go wrong with the Com usb cable with FTDI chipset?
update: I checked some more detailed pictures of the visonic kit and it seems like the "UTP"to Com cable is right ? when looking to it from the top the coloring is Brown/Brownwhite Green/Greenwhite Blue/Bluewhite Orange/Orangewhite.
I enrolled the Powerlink after I installed the software and told it to listen to “ftdi_sio” (Communicate using UART).
Or do I have to fix the “Lua Startup Failure” error bef?re I enroll. Please help me.
