Hi all,
I just noticed the rfxmgr program show an option to enable/disable the Somfy/RFY sun+wind detector
Is it available in the vera plugin??
Hi all,
No
Thanks for your reply.
It would be a nice addition
This feature is now available in the trunk version.
Wonderful! Thank you!!
@lolodomo & others
Just a question from a noob (me)
I have my 2 sun-window-screens and 1 sun-extending-screen (non-rts) automated with Fibaro Rollershutters modules (FGRM-222).
If I would buy the RFX and a Somfy/RFY sun+wind detector could I intergrate it in Vera so that I can contol the Fibaro Rollershutter modules if based on the Sun/Wind values?
What about more then 1 Somfy/RFY sun+wind detector with RFX? Is that possible?
What about the optional Somfy rainsensor that can be hooked up to the sun+wind detector?
Thanks in advance!
[quote=“mcalistair, post:6, topic:187086”]@lolodomo & others
Thanks in advance![/quote]
RFXtrx433E allows to enable/disable Sun/Wind sensor but not to retireve Sun/Wind values.
Oke thnx for the reply. Is it technically impossible? Or might it be added in a later stage?
Oke thnx for the reply. Is it technically impossible? Or might it be added in a later stage?[/quote]
No idea. Only RFXCOM could answer to that question.
The RFXtrx433E does not receive Somfy for technical reasons. (Somfy does not operate at 433.92MHz)
Thnx, that’s clear now. Pitty though
I have successfully added my Somfy windows coverings (normally control by sun-wind sensor or Somfy Telis 4 RTS remote) to the rfxtrx plugin. Now I want to be able to disable/enable my Somfy Solaris RTS sun-wind senors from Vera.
If understand the above thread correctly, is possible to do this in the latest plugin version from the trunk. I have installed that version but I don’t understand how to add, and to control, the sun-wind sensor.
You don’t have to add anything. Just use the UI (special commands in managed devices tab) or luup code in a scene (see link in the previous message).
Thank you for your help. I was so stuck i my head on adding the sun-wind sensor as a device that I didn’t look for any other option…
© 2022 Ezlo Innovation, All Rights Reserved. Terms of Use | Privacy Policy | Forum Rules
