Hi I’m getting loads of RFXtrx433 log entries, is anyone else ?
Any idea of the cause?
Is there anything I can do ?
06 10/28/20 23:04:54.286 Device_Variable::m_szValue_set device: 242 service: upnp-rfxcom-com:serviceId:rfxtrx1 variable: VeraTime was: 1603926284 now: 1603926294 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x71659520> 02 10/28/20 23:04:54.287 luup_log:242: RFXtrx: warning: No decode method for message: 0D 0A 3C 6D 73 67 3E 3C 73 72 63 3E 43 43 <0x71659520> 02 10/28/20 23:04:54.424 luup_log:242: RFXtrx: warning: Bad starting message; ignore byte 31 <0x71659520> 02 10/28/20 23:04:54.425 luup_log:242: RFXtrx: warning: Bad starting message; ignore byte 32 <0x71659520> 02 10/28/20 23:04:54.426 luup_log:242: RFXtrx: warning: Bad starting message; ignore byte 38 <0x71659520> 02 10/28/20 23:04:54.426 luup_log:242: RFXtrx: warning: Bad starting message; ignore byte 2D <0x71659520> 02 10/28/20 23:04:54.427 luup_log:242: RFXtrx: warning: Bad starting message; ignore byte 76 <0x71659520> 02 10/28/20 23:04:54.429 luup_log:242: RFXtrx: warning: Bad starting message; ignore byte 31 <0x71659520> 02 10/28/20 23:04:54.430 luup_log:242: RFXtrx: warning: Bad starting message; ignore byte 2E <0x71659520> 02 10/28/20 23:04:54.430 luup_log:242: RFXtrx: warning: Bad starting message; ignore byte 32 <0x71659520> 02 10/28/20 23:04:54.431 luup_log:242: RFXtrx: warning: Bad starting message; ignore byte 39 <0x71659520> 02 10/28/20 23:04:54.436 luup_log:242: RFXtrx: warning: Bad starting message; ignore byte 3C <0x71659520> 02 10/28/20 23:04:54.437 luup_log:242: RFXtrx: warning: Bad starting message; ignore byte 2F <0x71659520> 02 10/28/20 23:04:54.439 luup_log:242: RFXtrx: warning: Bad starting message; ignore byte 73 <0x71659520> 02 10/28/20 23:04:54.440 luup_log:242: RFXtrx: warning: Bad starting message; ignore byte 72 <0x71659520> 02 10/28/20 23:04:54.441 luup_log:242: RFXtrx: warning: Bad starting message; ignore byte 63 <0x71659520> 02 10/28/20 23:04:54.441 luup_log:242: RFXtrx: warning: Bad starting message; ignore byte 3E <0x71659520> 02 10/28/20 23:04:54.442 luup_log:242: RFXtrx: warning: Bad starting message; ignore byte 3C <0x71659520> 02 10/28/20 23:04:54.443 luup_log:242: RFXtrx: warning: Bad starting message; ignore byte 64 <0x71659520> 02 10/28/20 23:04:54.443 luup_log:242: RFXtrx: warning: Bad starting message; ignore byte 73 <0x71659520> 02 10/28/20 23:04:54.444 luup_log:242: RFXtrx: warning: Bad starting message; ignore byte 62 <0x71659520> 02 10/28/20 23:04:54.445 luup_log:242: RFXtrx: warning: Bad starting message; ignore byte 3E <0x71659520> 02 10/28/20 23:04:54.445 luup_log:242: RFXtrx: warning: Bad starting message; ignore byte 30 <0x71659520> 02 10/28/20 23:04:54.446 luup_log:242: RFXtrx: warning: Bad starting message; ignore byte 32 <0x71659520> 02 10/28/20 23:04:54.447 luup_log:242: RFXtrx: warning: Bad starting message; ignore byte 34 <0x71659520> 02 10/28/20 23:04:54.447 luup_log:242: RFXtrx: warning: Bad starting message; ignore byte 37 <0x71659520> 02 10/28/20 23:04:54.448 luup_log:242: RFXtrx: warning: Bad starting message; ignore byte 39 <0x71659520> 02 10/28/20 23:04:54.449 luup_log:242: RFXtrx: warning: Bad starting message; ignore byte 3C <0x71659520> 02 10/28/20 23:04:54.449 luup_log:242: RFXtrx: warning: Bad starting message; ignore byte 2F <0x71659520> 02 10/28/20 23:04:54.450 luup_log:242: RFXtrx: warning: Bad starting message; ignore byte 64 <0x71659520> 02 10/28/20 23:04:54.452 luup_log:242: RFXtrx: warning: Bad starting message; ignore byte 73 <0x71659520> 02 10/28/20 23:04:54.453 luup_log:242: RFXtrx: warning: Bad starting message; ignore byte 62 <0x71659520>
Etc etc…
