I own Livolo 1gang switches (no dimmer), Rfxtrx433E (beta3, f/w 233) and Vera3 (UI7). Switches able to run ‘All Off’ command (to be switched off for sure). In Rfxmngr this command available, but can’t find it in RFXtrx devices settings on Vera. Can plugin run All Off?[/quote]
If I correctly remember, the OFF button should trigger an all Off action while the ON button should trigger a toggle ON/OFF.[/quote]
a standing alone OFF button is not available in UI7, there is only switch ON/OFF and it switches devices depending on their current state: OFF->ON or ON->OFF. Could you make OFF function equal to ALL OFF for Livolo switches next releases?
@lolodomo Are either of the 433Mhz La Crosse TX7U (Temperature and Humidity) or TX6U (Temperature) sensors supported? Neither are listed on the compatibility chart. Thanks.
when i press the left button(s) for the first time it creates 2 devices, a light switch named RFX Light L5.0/F412A8/14 and a scene controller named RFX Remote L5.0/F412A8 with Mood 1 - 5 and Group Off buttons. When i press the right button(s) for the first time it adds a light switch named RFX Light L5.0/F412A8/13 (here is a screen shot Dropbox - File Deleted).
On the scene controller i have tried setting up notifications for activated and deactivated scenes 111 - 115 but none are triggered when i press any buttons.
I turned on RFX debug and looked at the log when i pressed each button, and it looks like it is activating and deactivating scenes 13 and 14. So i tried setting up notifications for those, but still no luck.
I would like to use each of the 4 buttons to trigger a different Vera scene. (It really is just a scene controller and there not light switches – it is not connected to mains or any load – so it seems odd that it creates switch devices)
How should i set that up? Thanks and sorry to bother you.
i was testing with the Notification tab in the remote device which did not work, but setting up the scene trigger does work. i should have tested that before bothering you. :embarrassed:
Do a search in the forum or take a look at the Micasaverde Wiki.
You have the option to install the InfoViewer plugin if using a SSH connection is to much difficult for you.
I’m having problems trying to create a LWRF switch. This is the first time I’ve tried to create a device since moving over to UI7. No matter what I try nothing seems to work. None of the tabs in the settings menu seem to work, so I can’t even enable or disable any of the options.
The protocol options change color when I hover over the box, but if I click the lighter color do not stick.
I have tried to refresh the browser. Is it an error with the FW?
Also, is BlindsT0 protocol the same as “RollerTrol/Hasta” in the app? I can’t get my Vera Edge with a RFXtrxE to recognize when I press my RollerTrol remote, even though I have enabled the RollerTrol/Hasta protocol. When i enable the same protocol on my VeraLite running UI5 with a RFXtrx I can see the remote presses are recognized.
Have anyone gotten a Rollertrol to work with UI7?
EDIT: Solved the issue with my Rollertrol blinds not being recognized with my Vera Edge and RFXtrxE. It seems I had RFXtrx433_Ext_236.hex FW installed. Flashed RFXtrx433_Type2_183.hex instead and now my RFXtrxE “hears” the signals from the remote!
