I’m trying to set up a RFXcom RFXtrx controller module to operate a “DC106, Yooda …” curtain motor using LightwaveRF. But I cannot create the “DC106 …” device. It appears in the selecion list under the RFXtrx app’s “New device” menu. I select it, fill in the required fields, then press “save”. It responds that Vera will reload the engine, but it doesn’t. Nothing happens - no new device, no nothing.
I followed the Vesternet APNT-116 User Guide, downloading the files and following the maual installation procedure.
I had this working before, on a Vera 3 running UI7, so it’s a mystery as to why it won’t work now.
You should get the ZIP file in this post. It contains the latest version of the plugin files. If you’re already using those files I suggest looking at the Vera log. You can do that from your browser: http://[your Vera IP address]/cgi-bin/cmh/log.sh?Device=LuaUPnP
Thanks for that. I had tried to find updated luup files, but couldn’t find them.
All updated now and working. At least, it looks that way. I’m controlling my Vera remotely, so I can’t verify whether or not the curtains open & close, but it’s looking good.
