RFX setup problem
Hi. I’m new to Vera and finding it a challenge but rewarding. Overall I’m doing ok with locks, thermostats, and sensors. I’m still waiting to hear from MCV regarding the firmware beta to operate my Aeotec mulit-sensor, but I’m holding my breath.
My problem is with the RFXCOM RFXrec433. I plugged in the unit as described and I think I uploaded the files ok. It said they uploaded anyway. I created the UnP device as per the instructions on here, but nothing happened. I’m trying to get an Oregon Scientific THWR800 temp sensor working and as I read it, it should auto configure and appear. Nothing on my UI5 screen except for the device I created. For some reason it did appear as on my Automater app in my iPad but no readings of any sort.
I’m sure I missed a step but I’d sure like to get the 433 devices working so I can add a couple more. Thanks for any direction and detail is appreciated as I’m still learning.
M
If you installed the one from the app store, it is the incorrect app.
The new released version for the RFXtrx see:
http://forum.micasaverde.com/index.php/topic,13822.0.html
Thanks!
So do I have to unnstall the old one first? If so, how?
I really appreciate the help.
M
You should uninstall the device by clicking on the rubbish bin located in the top right corner. You do not need to worry about the files.
I installed the new files with no change. I still only show the devices created and nothing else or any info.
Is there a difference in the procedure for the RFXCOM RFXrec433 than for the RFCtrx433???
Or am I still missing something silly on my end?
So after I created the device it should simply appear and start. Adding the sensors automatically?
We’ll get it yet. Thanks!
I adjusted the serial port as descibed but still objects showing other than the device I created. Does it have to be set to use the “serial port list” as a parent o next or something?
I not surewhatim missing yet.
Thanks!
Not sure about difference between rec, trx other than not being a transmitter. Try clicking the reload located in the top right to restart Vera.
Yeah I’ve tried that several times. I’ll look at it more tonight.
Thanks Brientim for your help. I got it up and running.RTFM right? ;D For some reason I only uploaded the .xml files before. Did them all and it worked just like it’s supposed to.
Any suggestions on how to get the temp sensors to read F instead of C?
Thanks again!
Never mind, I got it. Great to have it working!
Your welcome,
I am glad to hear you got it up and working.
