The MonoPrice Z-Wave Motion Detector with Temperature Sensor(PID:10796) is made by Vision Automotive Electronics. This is the same company that manufactures the Schlage RS200HC Motion Sensor. The two devices are very similar physically with a few exceptions.
Externally, the two devices are similar in dimensions. The most notable exception is the way that the MonoPrice unit’s face is angled downward at about 20 degrees, while the Schlage looks straight ahead. The Schlage unit comes with a mounting bracket which the motion sensor clips onto whereas the MonoPrice has no mounting bracket and only offers double-sided tape to stick the sensor onto the wall. This could present an issue when trying to replace the battery in the MonoPrice unit, since it may be cumbersome to remove the cover while the unit is attached to the wall.
While the internal circuitry looks identical, the MonoPrice has an angled PIR sensor to match its angled case. It also contains an integrated temperature sensor that I think is part of the Z-Wave chip. The Schlage unit has no temperature sensor.
Both devices have jumper pins labeled PET1, PET2 and TEST. The MonoPrice manual makes no reference to these pins. The Schlage manual explains that the PET jumpers decrease the sensitivity of the motion sensor so that small pets(PET1) and large pets(PET2) do not trigger the sensor. It further explains that the TEST jumper causes the no-motion untrip time to change to 5 seconds for testing and setup purposes. However, the TEST jumper does not seem to have any effect on the MonoPrice unit.
With Vera, the temperature reading from the MonoPrice motion sensor can be viewed on the Advanced tab in the Vera GUI. The variable can also be used in scenes, LUA code and PLEG. However if you wish to have the temperature displayed on the GUI or in a mobile app, you will need to add the iDoorContact plugin to Vera. Hopefully MCV will improve support for this device and eliminate the need for the plugin in the future.
Setup of the MonoPrice motion sensor is straightforward and adequately described in the manual. Some people on the forum seem to have had some difficulty understanding the process. Two important things to remember is that when a device does not seem to want to include, you should first exclude it and then include it. Also, the MonoPrice motion sensor’s cover should remain off, keeping the device awake, until the device is included and configured properly. Once the cover is installed, the device goes to sleep and may not configure properly.
Both the MonoPrice and the Schlage units work well with Vera. Battery life on the Schlage has been excellent. After six months, configured with the fast 5 second TEST reset, my Schlage batteries still show 100%. The Schlage manual claims a 3 year battery life expectancy and I expect the MonoPrice battery life to be equally as good. I was disappointed to not have any other choices but the 3 minute untrip reset interval with the MonoPrice motion sensor. I prefer a faster reset for more active scenes, but it is still perfectly usable with 3-5 minutes being fairly standard for motion sensors.
