I’ve been using schlage window sensors to monitor and alarm some misc things around my house. I want to monitor the septic high level float on my septic tank which is a normally open contact. The window sensor will show up as tripped in the Vera when in reality there is nothing wrong.
Is there any easy way to flip this in the controller?
I know I can alarm the sensor the way it is, I could also install a relay to reverse the logic of the high level float. I’m just wondering if there is a setting I can use to get the sensor to display correctly in the Vera with out doing additional wiring.
