I moved into a home which has AT&T digital life, I bought a VeraPlus to control the devices. I can’t reset the IP camera Sercomm OC-432 with the reset button behind the camera, also I don’t know the network camera username password (tried all the default combinations, none worked).
Also, the camera is connected to IP532CG PoE. If someone has been thru this process or knows how I can reuse the devices it will be of great help!
Thanks in advance.
