Hi , Thanks for adding the Require confirmation. I am wanting to use it to unlock front door. When turned on it works when i press the unlock button but it does not work when i set the lock to geofence. It just unlocks the door without asking when i get home.
any help would be appreciated…
thankyou
This has been asked before which has been put into the dev list - as you’ve seen it was only suppose to work when the app is open. I’ll be trying to enhance the notifications so that this can be controlled from there, but this will be a bit of effort - look for it in a future release though.
OK. Thankyou for the reply.
