I installed a Trane TZEMT400BB32MAA thermostat a year ago on a heatpump system with 2 stage heat .
With RichardTSchaefer’s help, I was able to get it connected correctly and has been working well.
I wrote a dashboard/logging website and it has helped me learn how/where to better insulate the house. I get a report from the verde each time something changes : temp, set temps, status (heat on, cool on), etc.
But I’ve never been able to get any info about whether the 2nd stage of heat has kicked in (auxiliary/emergency heat). Does anyone know if there is a way/variable to read to indicate 2nd stage?
Using the urn:schemas-upnp-org:device:HVAC_ZoneThermostat:1 plug in.c
Thank you!
