Repeater not working
I have a Vera 2 gateway and a SmartSwitch, along with other Z-Wave products from other manufacturers. I am using the Vera 2 as a controller and the Smart Switch as a lamp module/repeater. The SmartSwitch is working as a lamp module, but not as a repeater. It does not route packets to my GE wall outlet or my Wayne-Dalton lamp module. Does anyone know why?
How do you know it’s not routing the packets to your other switches? Did you try to set up manual routing or did you heal the Z-Wave network after you placed the devices in their final location?
Can you please submit a trouble ticket so we can take a look?
I think it’s not routing packets based on the fact that the other switches aren’t getting the packets. I have submitted a trouble ticket on Mi Casa’s website.
I thought all I needed to do for routing to work was to place the modules in their final locations. Is there some configuration that I have to do?
JOD.
Thank you, I will try healing the network.
I would like to fully understand why the repeaters do not work automatically. Why is it necessary to heal the network? For instance, if I were using my Wayne-Dalton master remote to control one lamp module through another repeater lamp module, there would be no way to heal the network. So how would the repeaters work in that case?
Vera (i.e. the controller) determines the routing, so she needs to have an accurate picture of the network, i.e. knowing the neighbors of every node.
So I would not be able to use repeaters with a simple remote, is that correct?
Whenever you change the topology, you’d have to update all the controllers so they have an accurate picture. Since remotes (i.e. a portable controller) can be anywhere in the network at any one time, they have their own way of getting a message to a node, but they will route through other nodes if the destination node cannot be reached directly.
How does the remote keep track of the modules’ locations? Does it get some kind of signal strength value for each node in the network every time it moves?
Then if it were out of range of any node on its network, it would just send commands for that node to all the rest? That means every node on the network would have to know its neighbors.
