Is there any way to rename a number of devices without a restart between each one? I am using ALTUI to rename them but each rename forces a luup restart - very time consuming.
Thanks,
M
Thanks,
M
Renaming with ALTUI does not cause a luup reload for me… doing it on UI7 does. Maybe try to change the name by editing the name field in the attributes page?
I just rename the device in the device’s Advanced > Params tab. I change room numbers that way, too.
Man, I wish I had known that as I was reorganizing my 12 PLEG devices last month.
Rafale, do you run altui on vera or elsewhere? When I was testing and running altui on a docker I was able to instantly rename device there as well.
I suppose your docker is actually openLuup. I run ALTUI on both a vera and on openLuup.
Yes it was. And on vera reload needed, on docker didnt.
