I’m using Prowl to push messages from VeraAlerts. I wonder if it’s possible to remove or replace the text “Vera Alerts” that every message is initiated with?
Each profile allows considerable ability to customize.
You need to read the API for the particular provider.
A link to each providers API is on the Profile tab for each profile.
In this case you need to add the following to the message:
{application:Your Application Name}
Many thanks. I will try it out.
