I’m sending a few alerts as email-to-text on my cell phone. The messages show up with a “Subject: Vera Plus” header, then the actual message on another line below the header. Can this header be removed somehow?
here my sample:
{DateTime(CurrentTime,%m/%d %T)} Garage door is ajar {Subject= }
And if you do not mind the subject being the same as the content:
In your MsgPrefix for the mail profile you can use:
{Subject={Msg}}
[quote=“RichardTSchaefer, post:3, topic:193998”]And if you do not mind the subject being the same as the content:
{Subject={Msg}}[/quote]
Thank you both. That works great for my notifications. Is there a way to remove the Subject: for the internal alerts? Like when Vera restarts?
[quote=“jmedemar”][quote=“RichardTSchaefer, post:3, topic:193998”]And if you do not mind the subject being the same as the content:
Thank you both. That works great for my notifications. Is there a way to remove the Subject: for the internal alerts? Like when Vera restarts?[/quote]
In Vera Alerts Settings disable internal Alerts or associate a profile to default recipients to receive these.
Sent from my SAMSUNG-SM-G935A using Tapatalk
