I had a faulty device that I returned to my supplier and need to now remove it from Vera. I had seen a “Permanently Remove Dead Device” button somewhere in Dashboard before in UI4 v1047 (which was very unreliable for me). I have upgraded to v1186 which is working great but I cant’ find this feature anywhere now.
That button has been removed. If you are lucky then you can use the delete button on the device itself as this is supposed to the the way it works now… however I have a similar problem with a device and when I try it, and it wont delete because the engine restarts
Click on the wrench for the dead device. Then click on the garbage can on the upper right corner. You will be in the “Zwave Device” tab and you will see a button “Permanently remove dead node” click on this.
[quote=“MP_777, post:5, topic:167727”]Click on the wrench for the dead device. Then click on the garbage can on the upper right corner. You will be in the “Zwave Device” tab and you will see a button “Permanently remove dead node” click on this.[/quote]Which firmware version are you using?
