After updating Home Buddy to the latest version, remote mode does not work anymore, but local does. I am still using UI2 and the following link produces output correctly.
https://ra2.findvera.com/username/password/49451/data_request?output_format=json&id=user_data2
This is the error I get:
Unable to parse data. Please check your settings.
The developer sent me v.20 to use while he looks into the issue.
There seems to be an inconsistency with the URL that MCV uses for UI2 units. I have a unit on ra1.findvera.com and it works fine, yours is on ra2.findvera.com – that may be where the problem is, I have yet to find out.
In the meantime, if you manually change your serial number in the setup to 49451, that should fix it. Please post back with the results. Thanks.
