I have been following this for a while and its looking good!!!
Now that I am having memory issues (overloaded Vera Lite) I am thinking i am going to set this up on a Ras Pi this weekend to take some of the load.
Just a couple of questions I have
How do we achieve remote access? do you use the ALT UI login? or do I need to setup a VPN?
2)To run this on a windows machine, does it need to be run in a Linux virtual machine or can I run under windows?
This is my setup… Using a VPN for now… MiOS routing that AltUI (and the Vera UI as well) relies on can only target a Vera machine that is registered with MCV Vera.
I am working on a reverse bridge idea during my spare time to access the OpenLuup machine from the Vera to address this (and be able to see both machines from the remote apps like HomeWave). Need to address some circularity issues and avoid recreating plug-ins that eat memeory on the host vera…
Not sure about your question on Windows… I personnaly test my set up in a Linux VM in Virtual Box on a Windows machine… I read somewhere on the forum that Windows can host openLuup but OS calls might create issues in certain cases
openLuup works on Windows, natively, but there may be some plugins which try to make use of OS features which aren’t always there. Depends on what you need. If it was just to run a bridge to Vera you should be OK. I don’t have a definitive list, sorry (can’t test everything), but ask if you need help.
For Pi I installed weaved (weaved.com) and defined a connection to port 3480. It sort of works in that I have to manually add the /data_request?id=lr_ALTUI_Handler&command=home… after making the connection. Weaved does not support adding anything to the host name. I know you can do something with redirects in lighttpd, but I have not tried it yet. Anyone with experience on that?
Also the images are not coming trough as you truly have access to port 3480 only. You can also setup ssh access. But for some occasional emergencies I cannot do by phone/vpn it is a way.
After a few hours of tinkering I can get something to happen on port 80 as that is where lighttpd is running. However, on port 3480 openLuup is calling the shots. It took me most of tonight to get to that duh… moment : So if any redirects are required on port 3480 I can try changing the lighttpd config till I’m blue in the face, but it is not going to happen.
The only option is to hack the server.lua and in the receive function for the GET method change an empty path
if (path == "/") then
path = "/data_request?id=lr_ALTUI_Handler&command=home"
I tried that and it actually works and it does not yet like I broke anything :D.
So if you want remote access, have a look at weaved.com and setup a connection to port 3480. It is pretty simple to do. You can then add the /data_request… by hand after connecting or hack akbooer great work over and over as I am not sure he would like to add this as a default option ;). O, and images do not work as you truly only have a connection to port 3480 this way, not on 80 too.
[sup]This is my setup… Using a VPN for now… MiOS routing that AltUI (and the Vera UI as well) relies on can only target a Vera machine that is registered with MCV Vera.
I am working on a reverse bridge idea during my spare time to access the OpenLuup machine from the Vera to address this (and be able to see both machines from the remote apps like HomeWave). Need to address some circularity issues and avoid recreating plug-ins that eat memeory on the host vera…[/sup]
[sub]
I really like the sound of the reverse bridge. I will be looking out for that!!![/sub]
I guess one other thing I am trying to get my head around is how everyone is handling there logic if PLEG is not supported?
Does ALT UI have anything different to Veras Lua?
This is my setup... Using a VPN for now... MiOS routing that AltUI (and the Vera UI as well) relies on can only target a Vera machine that is registered with MCV Vera.
I am working on a reverse bridge idea during my spare time to access the OpenLuup machine from the Vera to address this (and be able to see both machines from the remote apps like HomeWave). Need to address some circularity issues and avoid recreating plug-ins that eat memeory on the host vera...
[quote=“JCH, post:13, topic:191102”]I guess one other thing I am trying to get my head around is how everyone is handling there logic if PLEG is not supported?
Does ALT UI have anything different to Veras Lua?[/quote]
Yes, it has device variable watch triggers (which, in fact, is what PLEG uses as well) and then you can use straight-forward Lua expressions or a graphical blockly user interface to define your conditional logic.
I really don’t see any down side to having that as a default. Happy to add if it makes things easier (unless there IS a problem.)[/quote]
So my subtle winking helped ;D. It would be brilliant if it could be something you can define in startup.lua as a top-level attribute?
I’ve just realised that if, on loading, I convert all icon file references in .json files to HTTP port 3480 references, then this should work just fine with remote (or local) access.
Did you have an opportunity to test Ak’s latest change ? I’m curious as I’m still maybe a day or so out before I can. I had to reach out to Weaved this morning as they don’t have an installer for OpenWrt on an ARM device. Seems I’m the first to ask (wait till I ask for an x86 installer) so they provided me with really good instructions to manually load using various binaries (I need to find one that’s compatible). So if you don’t get a chance then I should be able to hopefully soon.
