gipelo
1
when I use the
https://fwd2.mios.com/login/password/N?vera/data_request?output_format=json&id=user_data
I have a blank screen in my webbrowser
(I have tryed with fwd1…same result)
if I change the login or password or N?vera… I have a error message (thats normal)
what I’m doing wrong ?
You have yo use the fwd server that is assigned to your unit … and it can change over time.
You find out with which one by calling:
http://sta1.mios.com/locator_json.php
While on your LAN.
futzle
3
[quote=“RichardTSchaefer”]You find out with which one by calling:
http://sta1.mios.com/locator_json.php[/quote]
May I strongly advise that developers use the SSL/TLS version at
https://sta1.mios.com/locator_json.php
? This is what MCV recommends now, and it’s what you’ll find in the wiki.
[quote=“futzle”][quote=“RichardTSchaefer”]You find out with which one by calling:
? This is what MCV recommends now, and it’s what you’ll find in the wiki.[/quote]
Made my change awhile back.
gipelo
5
thanks for the information it work well now
