remaining problem to setup 3-in-1 sensor motion detection in IU4
I just setup a 3-in-1 sensor in order to highlight automaticly a lamp when motion is detected.
I have had trouble to change the default value of variable 2 from 20 to 1 in order to change more quickly the sensor status after end of detection.
Variable=2 Data Size=1 byte Dec Desired Value=1, seems only taken in account if any other variable is set with a data Size equal to “default”.
If I try to setup an other variable, for example, decrease sensitivity :
Variable=1 Data Size=1 byte Dec Desired Value=100
the setup aborts with an error…
