We’ve released today a new RTOS v.8.514 for Ezlo Atom and Ezlo PlugHub Improvements:
Improvement in stability
Improved connectivity to cloud servers
Memory usage optimization
Fixes:
Fixed the issue about not being able to change the color on Zwave RGB bulbs
Bug fixing on Z-Wave devices
Known issues:
Issue on Plughub where in case switch on / off manually the Led does not light up after power on.
Issue with incorrect sunrise/sunset time for scene in case the timezone is changed after enrollment. The sunrise/sunset scenes are calculated based on location and for the moment we do not have UI support to change it after enrollment (API is in progress of being integrated in UI)
Issue on devices that support Tamper where the broadcasts and notifications generated are opposite to the actual tamper state.
Issue on certain setups where the list of scenes might not displayed temporary in the mobile apps. We are working to find the root cause and fix the issue
No, it should upgrade automatically, or after a power cycle.
I’m asking a colleague to look into this issue, most probably I’ll send you a DM to ask the details about your Atom.
Both of my Atom V2s are also running 0.8.798 (presumably v.8.798?). If it weren’t for the April 22 build date, I’d say that 0.8.798 is later than 0.8.514… The Ezlo team is looking at my Atom V2s so I am sure they will shed light on the mystery.
If you do a hub.info.get in the API toll it will tell you that level of detail.
For me it also shows that the location settings are wrong, but I have no idea how to correct those. Other that full reset and install from scratch, and that should not be needed for this type of change.
