Improvements:
- Additional improvements to Reachable / Unreachable states for Z-Wave devices.
Newly integrated devices:
- Zlink Plug-In Dimmer PD-100
- Honeywell Z-Wave Thermostat YTH8320ZW1007
- Honeywell In-Wall Tamper Resistant Outlet ZW1002/39349
- HomeSeer Floodlight Sensor HS-FLS100+
- Aeotec Recessed Door Sensor ZW089
- GE In-Wall Smart Dimmer 14294 / ZW3005
- Nexia Temperature & Humidity Sensor TH100NX
- HomeSeer Flex Sensor HS-FS100+
- Evolve Dual Outlet Receptacle LOM-15
Newly integrated devices with known issues:
- Hank HKZW-RGB01 RGB Bulb
- Ring Range Extender
- Honeywell 39339/ZW3107 Plug-in Smart Dimmer
- Honeywell Plug-in Switch (Single Plug) ZW4103/39337
- Honeywell Plug-in Outdoor Switch ZW4201/39346
- Zipato rgbw2 us Bulb
- Leviton DZ6HD Dimmer
- Zooz Zen27 S2 Dimmer
- Aeotec LED Bulb 6 Multi-White ZWA001-A
- Aeotec ZWA002 LED Bulb 6:Multi-Colour
- Evolve Plug-In Module LPM-15
- Aeotec ZW121 LED Strip
- Yale YRD240 Touchscreen Deadbolt (No support yet for PIN codes, restrictions and notifications)
- Schlage BE469NX Touchscreen Deadbolt (No support yet for PIN codes, restrictions and notifications)
- Fibaro Double Switch 2 FGS-223
- Enerwave IN-Wall Smart Meter TR Duplex Receptacle ZW15RM-PLUS
- Ecolink Z-Wave Plus Smart Switch - Double Rocker DDLS2-ZWAVE5
- Ecolink Z-Wave Plus Smart Switch - Single Rocker SDLS2-ZWAVE5
- Remotec US Binary Switch ZFM-80
- GE Plug-in Smart Switch ZW4103/28169
- HomeSeer Z-Wave Plus Door/Window Sensor HS-DS100+
- Ecolink Garage Door Tilt Sensor TILTZWAVE2.5-ECO
- GE Plug-in Smart Switch, Dual Plug ZW4106/14282
Known issues on newly integrated devices:
- Issues on the Hank HKZW-RGB01 RGB Bulb with the status of the device not being updated when controlling the device manually and the light-bulb icon does not distinguish from background when is set to 100% white.
- Issues with Range extenders / repeaters being displayed as generic devices.
- Issues on the zipato rgbw2 us Bulb where the color settings are not retained when creating a scene with action using a colored bulb.
- Issues on the Leviton DZ6HD Dimmer with the status of the device not being updated when controlling the device manually .
- Issues on the Zooz Zen27 S2 Dimmer with the status of the device not being updated when controlling the device manually.
- Issue on Aeotec ZWA001-A with not being able to switch to warm/cold white.
- Issue with the ON/OFF state not being persisting when creating a scene with action using a dimmer.
- Issue on Aeotec LED Bulb 6 Multi-White ZWA001-A with the light-bulb icon does not distinguish from background when is set to 100% white.
- Issues with Evolve Plug-In Module LPM-15 being detected as a in-wall switch.
- Issues with no updated RGB values for Aeotec ZW121.
- Issue with no instant status for the ‘child’ devices created for Fibaro FGS-223.
- Issues with Fibaro Single Switch 2 FGS-223 being recognized as an outdoor switch.
- Inconsistency for Aeotec ZW139 Nano Switchicon on iOS icon.
- Issue with Honeywell Plug-in Switch (Single Plug) ZW4103/39337 being detected as a in-wall switch.
- Issue on Ecolink Z-Wave Plus Smart Switch - Single Rocker SDLS2-ZWAVE5 where the battery low warning is displayed as 100%
- Issue with the Color of RGB bulbs not being persisted.
- Issue with Ecolink Garage Door Tilt Sensor TILTZWAVE2.5-ECO being detected as a door/window sensor.
Other known issues:
- Issue with no events being generated when tampering a security sensor.
- Issue with armed and tripped leak / flood sensors don’t notify users
- Issue with the controller resetting to factory defaults after multiple actions that are causing a crash.
