New features:
- Added support for Local Access Phase 1 - ability to create scenes that are triggered by other devices and use scene controllers as triggers in scenes. This way, independent of an Internet connection, you will be able to run your scenes whenever you want*
- Added support for extended scene creation options (devices as triggers)*
- Added support to set pin codes for door locks*
*Please note that for accessing the PIN codes and device triggered scenes features you will need the latest BETA mobile apps that you can get by doing the enrolment in the Beta program: Early Beta - Local Access Phase 1 - Official Announcements - Ezlo Community .
If you are already part of the Android Beta group you can just update to the latest version 7.33.332, otherwise you can join by following the steps described here: The new VERA Dashboard preview (Android)! - #9 by Sorin - VeraMobile - Ezlo Community.
The iOS beta app will be available soon.
Fixes:
- Fixed the issue on PlugHub with the LED status no longer reflecting WiFi connection status once the user does an on/off action
- Fixed the issue with Inverted LED values for some of the first revisions of the PlugHub
- Fixed the issue on Fibaro FGWPB-111/FGWPB-121 Wall Plug with the device status not updated when controlling the device from the mobile apps.
Newly integrated devices:
GE/Jasco Enbrighten Smart LED Bulb 39723
Leviton DZPA1 Plug-In Outlet
Jasco In Wall Dimmer 14321/ZW3005 (No DPW)
Honeywell 39358 / ZW4002 In-Wall Fan Control (No DPW)
GE/Jasco 14289/ZW3009 In-Wall Touch Sensing Smart Dimmer (No DPW)
Sensative Strips-MaZw 11 01 01x Door/Window Sensor
Aeotec ZWA005 TriSensor
GoControl Dimmable LED Indoor Flood Light LBR30Z-1
Zooz ZEN22 Dimmer Light Switch
Philio PSP05 Single Function PIR
Everspring SF813 Smoke Sensor
Satco On/Off Appliance Module 86-100
Aeotec DSC27103 Micro Smart Dimmer G2 (No DPW)
Zooz ZEN24 Toggle Dimmer Switch (No DPW)
Honeywell 39351 / ZW3005 In-Wall Dimmer (No DPW)
Jasco ZW3011 In-Wall Smart Dimmer (No DPW)
Jasco ZW3010 In-Wall Smart Dimmer (No DPW)
Inovelli LZW31 Dimmer Switch (No DPW)
Remotec ZDS-200NA Dimming Switch Module (No DPW)
Everspring SM810 Door/Window Detector (No DPW)
Aeotec ZW112 Door/Window Sensor 6
Everspring HSM02-0 Door/Window Sensor
Newly integrated devices with known issues:
Jasco In-Wall Smart Switch 14318/ZW4005
GE/Jasco 14288/ZW1002 In-Wall Tamper Resistant Smart Outlet
Aspire RF Tamper Resistant Duplex Receptacle RFTR9505-T
Honeywell In-Wall Switch (Toggle) ZW4003
Ecolink Home Motion Sensor PIRZWAVE2.5-ECO
Schlage BE469ZP Smart Deadbolt
Danalock V3-BTZU door Lock
ASPIRE RF Wireless by Eaton Wiring RF9518 8A Wireless Switch
Philio Door Lock PDS-100
Enerwave ZW15S MIn-Wall Smart Meter ON/OFF Switch
Leviton Decora Smart Switch DZ15S
Kwikset 914C Convert Smart Lock
Somfy Z-WAVE to ILT interface 1870171 RevA
Enerwave ZW500DM In-wall Smart Meter Dimmer Switch
Intermatic Portable Remote Controller PE953
Aeotec Range Extender 7 ZW189
Aeotec Recessed Door Sensor 7 ZW187
Hank Smart Plug HKZW-SO03
Cooper RF9501 Single Pole Switch
GE/Jasco Plug-in Smart Dimmer 28175/ZW3106
Everspring SE812 Indoor Siren
Oomi Color Strip FT121-A
Ecolink DTLS2-ZWAVE5 Dual Toggle Light Switch
Eaton Z-Wave Plus Wireless Receptacle RFTR9605-T
Ecolink STLS2-ZWAVE5 Single Toggle Light Switch
Sunricher SR-ZV9040A-B Micro Smart Dimmer
Aeotec ZW110 Smart Switch 6
Remotec ZRP-100NA Repeater
Jasco ZW4008DV In-Wall Smart Switch
Zipato rgbwe27zw RGBW light bulb
Known issues on newly integrated devices:
Inconsistency for In-wall Switches icon on iOS for Jasco In-Wall Smart Switch 14318/ZW4005
Inconsistency for In-wall Switches icon on iOS for GE/Jasco 14288/ZW1002 In-Wall Tamper Resistant Smart Outlet
Inconsistency for In-wall Switches icon on iOS for Aspire RF Tamper Resistant Duplex Receptacle RFTR9505-T
Inconsistency for In-wall Switches icon on iOS for Honeywell In-Wall Switch (Toggle) ZW4003
Issue with a second device (notification type device - for power management events) created for Ecolink Home Motion Sensor PIRZWAVE2.5-ECO
Issue on Schlage BE469ZP Smart Deadbolt Door lock icon that looks different than the one on Android.
Issue on IOS with Danalock V3-BTZU Door lock icon that looks different than the one on Android.
Issue on iOS with Hank Smart Plug HKZW-SO03 icon that looks different than the one on Android.
Issue on iOS with Cooper RF9501 Single Pole Switch icon that looks different than the one on Android.
Issue on iOS app with Ecolink DTLS2-ZWAVE5 Dual Toggle Light Switch icon that looks different than the one on Android.
Issue on iOS on ASPIRE RF Wireless by Eaton Wiring RF9518 8A Wireless Switch icon that looks different than the one on Android.
Issue on iOS on Philia Door Lock PDS-100 icon that looks different than the one on Android.
Issue on iOS on Enerwave ZW15S MIn-Wall Smart Meter ON/OFF Switch icon that looks different than the one on Android.
Issue on Leviton Decora Smart Switch DZ15S icon that looks different than the one on the web UI / Android.
Issue on iOS on Kwikset 914C Convert Smart Lock icon that looks different than the one on Android.
Issue on iOS with Issue on iOS with Ecolink STLS2-ZWAVE5 Single Toggle Light Switch *that looks different than the one on Android.
Issue on iOS with Jasco ZW4008DV In-Wall Smart Switch *icon that looks different than the one on Android.
Issue on Somfy Z-WAVE to ILT interface 1870171 RevA where after iclusion the roller shutter device card has an on / off switch and issue on the iOS app with icon that looks different than the one on the web UI / Android
Issue on the Android app for the Enerwave ZW500DM In-wall Smart Meter Dimmer Switch where the Energy report is not displayed for this device.
Issue with the Intermatic Portable Remote Controller PE953 where no info related with scene controllers should be present in the device control section from Android App and the icon is not correct in Device wizard> Step 3. There is also an issue on iOS with Remotes are showing up on iOS as generic devices
Issue with Aeotec Range Extender 7 ZW189 being displayed as generic device on the mobile apps.
Issue on Aeotec Recessed Door Sensor 7 ZW187 with an an additional 2nd device (notification type device - for power management events) created after including the device.
Issue on GE/Jasco Plug-in Smart Dimmer 28175/ZW3106 with child devices getting the same name as the parent at inclusion
Issue on Everspring SE812 Indoor Siren with missing tamper notification report from
Issue on the iOS app for Oomi Color Strip FT121-A where the light-bulb icon does not distinguish from background when is set to 100% white
Issue on Android with Oomi Color Strip FT121-A where Color settings are not retained when creating a scene with action using a device.
issue with Eaton RFTR9605-T device being detected as a Cooper device upon pairing and isssue with the device icon on iOS icon that looks different than the one on the web UI / Android.
Issues on Sunricher SR-ZV9040A-B Micro Smart Dimmer where Meter values are not shown in the parent device on the Android app and no instant status reported when the device is paired with encryption
Issue on Aeotec ZW110 Smart Switch 6 with no energy report and No instant status.
Issue Remotec ZRP-100NA Repeater being displayed as a generic device on the mobile apps and under incorrect category name.
Issue on iOS with the Zipato rgbwe27zw RGBW light bulb where the light-bulb icon does not distinguish from background when is set to 100% white
Issue with additional unnecessary child device being created for Fibaro FGWPB-111
Other known issues:
- Issue with no events being generated when tampering a security sensor.
- Issue with armed and tripped leak / flood sensors don’t notify users
- Issue with the controller resetting to factory defaults after multiple actions that are causing a crash.
