Hi everyone,
We’ve released a new **EzVidoo release v.0.12.0 **
You can download it both for Windows or Linux under its homepage. www.ezvidoo.com
EzVidoo is a full-blown CCTV capability that has a hub running in it that can run both in Windows and Linux environments. It is FREE to install and use it locally on your own computers!
EzVidoo is the Next gen CCTV because it has a hub built-in. So with EzVidoo you can run Ezlo hub firmware on your own Windows PC or a Linux Computer. You can also transform any IP camera that supports RTSP protocol into a motion detection trigger device for your smart home system. World’s first Free CCTV software that has a full blown Hub Firmware built in running both windows or linux.
New Features
- Search activities, clips, histories by tags
- Testing hotzones,faces works now
- sound dB thresholding
- webRTC fast start, sub-second live stream open
- able to ON/OFF 2/24 history recording
- able to adjust clip duration
- able to reach vidoo over webUI from remote computer
Bug Fixes
- Fixed pts/dts timings of generated video clips for certain cameras
- clip jumps to end after start
- recorded clips are all same for certain cameras
- Fixed blurry images in snapshots,videos,streaming
- accept face images without any size limit
- recorded videos lenght errors, limit 1:30 recorded 4:49
- webRTC connections breaking
- UI fixes, settings, zones, history,clip duration displays
- MQTT cannot connect on remote connection
- further improvement camera search, due to UFW linux, windows firewall, UDP rules
- development improvements, auto image generation with packer
