This started happening on my Vera Lite in the last month or so. 1.7.619 exhibits the problem but it might not be the first firmware that demonstrated it.
Symptom: My Vision Garage Door Tilt sensor stays tripped even when the garage door is closed. Actually, it quickly switches from tripped to untripped and then immediately back to tripped.
I know that the sensor is physically fine because I can see the state change in the log when I tilt the sensor to the untripped position in my hand:
06 08/15/15 15:16:34.175 Device_Variable::m_szValue_set device: 158 service: urn:micasaverde-com:serviceId:SecuritySensor1 variable: LastUntrip was: 1439615731 now: 1439615794 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2bbc7680>
06 08/15/15 15:16:34.176 Device_Variable::m_szValue_set device: 158 service: urn:micasaverde-com:serviceId:SecuritySensor1 variable: LastUntripAlert was: 1439615731 now: 1439615794 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2bbc7680>
06 08/15/15 15:16:34.177 Device_Variable::m_szValue_set device: 158 service: urn:micasaverde-com:serviceId:SecuritySensor1 variable: Tripped was: 1 now: 0 #hooks: 0 upnp: 0 skip: 0 v:0xe7e4f8/NONE duplicate:0 <0x2bbc7680>
06 08/15/15 15:16:34.178 Device_Variable::m_szValue_set device: 158 service: urn:micasaverde-com:serviceId:SecuritySensor1 variable: ArmedTripped was: 0 now: 0 #hooks: 0 upnp: 0 skip: 0 v:0x111b340/DL_ARMEDTRIPPED duplicate:1 <0x2bbc7680>
06 08/15/15 15:16:34.205 Device_Variable::m_szValue_set device: 158 service: urn:micasaverde-com:serviceId:SecuritySensor1 variable: LastTrip was: 1439615731 now: 1439615794 #hooks: 0 upnp: 0 skip: 0 v:0x11262b8/NONE duplicate:0 <0x2bbc7680>
06 08/15/15 15:16:34.206 Device_Variable::m_szValue_set device: 158 service: urn:micasaverde-com:serviceId:SecuritySensor1 variable: LastTripAlert was: 1439615731 now: 1439615794 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2bbc7680>
06 08/15/15 15:16:34.207 Device_Variable::m_szValue_set device: 158 service: urn:micasaverde-com:serviceId:SecuritySensor1 variable: Tripped was: 0 now: 1 #hooks: 0 upnp: 0 skip: 0 v:0xe7e4f8/NONE duplicate:0 <0x2bbc7680>
35 08/15/15 15:16:34.208 Device_Basic::ProcessSensorTrip device: 158 ignore 1:C;2:C;3:C;4:C/1 armed:0 <0x2bbc7680>
02 08/15/15 15:16:34.208 ZWaveNode::HandlePollUpdate_Alarm node 42 device 158 v1type: 7 v1level: 0 source: 0 status: 255 type: 7 event: 2 parms: 0 code: TRIP_ALARM <0x2bbc7680>
and then when I tilt the sensor into the tripped position I see:
02 08/15/15 15:16:29.025 ZWaveNode::HandlePollUpdate_Alarm node 42 device 158 v1type: 7 v1level: 255 source: 0 status: 255 type: 7 event: 2 parms: 0 code: TRIP_ALARM <0x2bbc7680>
06 08/15/15 15:16:29.026 Device_Variable::m_szValue_set device: 158 service: urn:micasaverde-com:serviceId:HaDevice1 variable: sl_Alarm was: TRIP_ALARM now: TRIP_ALARM #hooks: 0 upnp: 0 skip: 0 v:0x1088bb8/SL_ALARM duplicate:0 <0x2bbc7680>
Note the v1level value switches between 0 and 255.
The battery is at 83% and it seems to have gone through configuration properly.
I’ll raise a support ticket. This post is just to keep tabs on MCV’s progress in fixing the regression.
