I experienced this "can’t connect " lately a lot.
When I looked at this status page I could see that it seems that the Vera servers are down.
Well there not.
I also noticed that on top it states that it uses the cell connection but I have wifi turned on ?
My cell in the house is very spotty and if Veramate is really trying and using the cell network it will most likely not work.
So, I noticed that I have also turned in “phone calls over wifi”.
I tried and when I turn this “phone calls over wifi” off then Veramate will connect right away.
This is on iPhone 6+ with version 9.3.2 on Verizon.
And Veramate version 10.10.1.2 premium.
So, when you have this “refreshing” error, check what network Veramate tries to use and see if it makes sense.
I have a new 10.11 beta version I’m currently testing if anyone would wish to try if you’re getting this error a lot. Please use the in-app contact screen to “send diagnostics” and request access if you’d like to.
There is sometimes a limit to what VeraMate can do, but I’m attempting to handle some more errors etc from users feedback - I’m hoping this might help.
I could not login to my Veramate anymore with the latest login. There is a hand icon. When i clicked on it, it showed a few error messages that the app could not connect to the login server. My native Vera app is still working though.
I’ve currently 3 (possible 4) reports which have been having trouble logging on this week, however I can’t find a correlation to the 10.11 changes.
If they’re all the same (awaiting further diagnostics), it appears the UI7 authentication request has been returning “no data” from the Micasaverde servers - this is from the exact same command VeraMate was using even a month ago, so this is almost certainly something changed on the micasaverde servers.
The login definitely works with the official app (on cellular)? Could you try rebooting your Vera box?
I believe I’ve found the issue for users who are simply not able to login - this was due to a 10.11 issue not handling multiple veras correctly. If you create a user who only has access to one box, that should allow you to login.
I’m getting an emergency release out which hopefully we can push through, and a beta for affected users (PM your login/email/VeraMate version if you would like access).
I just started having this problem today, august 18, 2016. Is there something in this June fix that would still be lingering for any of us? I believe I noticed the app updating perhaps even yesterday. I have rebooted the router, the vera lite (ui5), and the iPhone 5s. multiple times. i was not able to connect either locally nor at my coffee shop. Simply says refreshing please wait and does not update the status of anything. thank you
