I have an issue which the UI doesn’t explain. On every device I see a cog icon, and also a pencil icon (in previous firmware versions, just a warning/hazard icon). When I hover over these two icons the cog says ‘job failed:’ and the pencil says ‘Job Successful: Job completed ok: Successfully polled node’.
It’s always shown them, but the devices work fine. With the previous firmware the icons were clickable and took me to the wiki, now the ‘learn more’ link at the top takes me to the wiki (same page) but the page is blank. I would populate the wiki page, if I knew what was wrong and how to solve it.
Your device does not report its manufacturer info (version and model) back to Vera. It appears there are too many such devices (usually, low-end ones) and Vera shouldn’t mark them as faulty.
I’ve seen you say this a few times in the forums. Could you possibly remember to quote the version number of the ‘next version’ for future reference, or if you don’t know that version number yet, maybe quote the last firmware version that will have the problem. It’s very hard to tell from such a vague statement whether I have or haven’t got a fixed version (yet).
