Recommendation for lighting system/remote?
Hi, I’m thinking of getting a veralite for automation, but I’m looking for a recommendation for what to use for simple (on/off, no dimming) lighting. Basically, I need a system that has a simple one-button/switch remote that can be put on a side table or wall. For bedrooms, I want to control the main lights via a simple remote – something that my elderly relatives can use without a smartphone. I can’t use a wired, in-wall switch because my switches only have 2 wires and a ground.
I’m surprised that micasaverde doesn’t have a simple remote. Insteon has such a remote, but the insteon reviews don’t seem to be good.
What are people here using? Thanks.
Welcome to the forum.
It rather depends where you are in the world as to what hardware solutions are available - major differences, for example, between thee USA and Europe. I am in the UK.
For simple (but four button) remotes, I use Aeotec (Aeon labs) MiniMote, which has a good configuration panel in Vera, is rechargeable by USB and lasts for months without recharging. I have some of these in the guest bedrooms (and elsewhere) and they’re easy to use.
I see that there’s a chunky and nice-looking single-button switch from QEES [url=http://www.vesternet.com/z-wave-qees-switch-and-power-meter]http://www.vesternet.com/z-wave-qees-switch-and-power-meter[/url], but have no experience of that.
For the actuators themselves, with your two-wire constraint, you might look at the Fibaro dimmer FGD211. Yes, I know it’s a dimmer, but you can configure it not to dim and I use it to turn on/off ceiling lights where I have no neutral wire available. Plays nicely with Vera.
