Does anyone know how to correct this error or ideas to debug it? I’m seeing it in my log file about every 1 minute.
Thanks,
John
Dec 29, 2017 4:06:23 PM I:VeraConnect.VeraGateway:URLConnection:https://fwd6.mios.com/<user_name>/PASSWORD/<vera_SN>/data_request?output_format=json&id=user_data2
Dec 29, 2017 4:06:25 PM E:VeraConnect.VeraGateway:FromString
Exception:org.json.JSONException: A JSONObject text must begin with ‘{’ at 1 [character 2 line 1]
at org.json.JSONTokener.syntaxError(JSONTokener.java:451)
at org.json.JSONObject.(JSONObject.java:195)
at org.json.JSONObject.(JSONObject.java:319)
at com.rtsservices.veraconnect.access.VeraGateway.FromString(VeraGateway.java:56)
at com.rtsservices.veraconnect.access.UI5Gateway$UI5VeraAccess.FetchJSONURL(UI5Gateway.java:158)
at com.rtsservices.conciergeserver.VeraService$VeraChannel.run(VeraService.java:165)
at java.lang.Thread.run(Thread.java:748)
It will probably go away … it means your Vera is down or maybe restarting.
Hi Richard,
Thanks for your reply. I’m sure that my Vera is up and running and no reloads are occurring. I do have a very large network…
Any thoughts on how I might be able to debug?
Thanks,
John
Also, it looks like this may have something to do with VC switching to fwd6.mios.com
Jan 21, 2018 12:05:24 PM I:VeraConnect.VeraGateway:URLConnection:http://<VERA_LOCAL_IP>/port_3480/data_request?output_format=json&id=lu_status2&DataVersion=553439384&LoadTime=1516553439
Jan 21, 2018 12:05:26 PM V:VeraService:ParseLuStatus:19
Jan 21, 2018 12:05:59 PM I:VeraConnect.VeraGateway:URLConnection:https://fwd6.mios.com/<VERA_USER>/PASSWORD/<VERA_SN>/data_request?output_format=json&id=user_data2
Jan 21, 2018 12:06:00 PM E:VeraConnect.VeraGateway:FromString
John
The error is actually coming up because the VCS is attempting to connect to a secondary powered off Vera3. The MiOS user I was using for the integration was actually part of the secondary Vera3 at one time. I verified that that user did not have access to the other Vera3.
I completely removed VCS and reinstalled it using a new MiOS user that only has access to my primary Vera3, the messages are still appearing.
Any idea as to how to eliminate the secondary Vera3 from VCS?
Thanks,
John
I’m getting the same error, reported it a few days ago.
I found that I had to leave my second Vera3 not only powered on, but I also had to add the newly created MiOS User to that unit. If I do that, I do not get errors.
Any ideas on how to exclude my second Vera3 from VCS?
Thanks,
John
From Cloud based Vera Concierge … go to your Home accounts … you can remove that Vera.
I have done the following:
Removed my integration user from my second Vera
Powered off my second Vera
Removed my second Vera from “https://veraconcierge.appspot.com/web/Account” under Associated Vera Controllers
Restarted my local VCS
My Seconds Vera still shows up under Vera Devices on my local VCS and I’m still receiving the error.
Any idea?
Richard,
I still cannot get the second Vera removed, no matter what I try.
Any other ideas?
John
