I have a Reactor sensor set up for motion on lights and I am wondering if I have set it up correctly because I seem to have a lot of activity in the log during the day when no one is in the room
Should this be happening, please see log below
I get this log activity through the day
Matsohl
November 10, 2020, 7:05pm
#2
It doesn´t seem that it is your devices in the Cinema room that is causing this. It seems that you have more logic, can you pass all of it with a Logic summary from the tools. Not just a screen shot.
Thank you
*************************************************** REACTOR LOGIC SUMMARY REPORT ***************************************************
Version: 3.8-20262 config 20190 cdata 20045 ui 20190 pluginDevice 15 LuaXP 1.0.2enh
System: Vera version 1.7.5186 (7.31) on Sercomm G450 ID 36 (Vera Plus); loadtime 1605037923/1605037935; systemReady 1605037940
Env: Lua 5.1; JSON dkjson 2.5+LPeg; UnsafeLua=nil/true
Local time: 2020-11-10T19:53:24+0000; DST=0; Lutterworth, England United Kingdom; formats %d/%m/%Y %H:%M:%S
House mode: plugin 1; system 1; tracking off
Sun data: {"source":"int","civdawn":1604990443,"nautdawn":1604987974,"sunset":1605025180,"nautdusk":1605029884,"stamp":2020315,"latitude":52.4563,"astrodusk":1605032278,"longitude":-1.20218,"civdusk":1605027415,"astrodawn":1604985580,"sunrise":1604992678}
Geofence: not running
RS: 1604986490,1604995481,1604996075,1605007044,1605012753,1605027455,1605031661,1605032620,1605035813,1605037935
NS: 0:X,1601118480:U,1604746320:D,1604747040:U,946684980:D,946685040:U,1604921520:D,946684980:U
Motion TV & Cinema (#314)
Version 20045.122 11/09/20 23:49:38
Message/status: Not tripped
Condition group "Reactor Sensor 22" (AND) false as of 11-09.19:30:56 <root>
&-?-comment "" <condyiqoa1r>
&-F-group "Motion Toilet" (AND) false as of 18:40:12 <grpyn7t2jb>
| &-T-sun bet sunset+0,sunrise+0 [1605037573 => 1605037936 at 19:52:16; T/T as of 16:19:00/16:19:00] <condyn7tsvd>
| &-F-service Guest Toilet Sensor (350) urn:micasaverde-com:serviceId:SecuritySensor1/Tripped = 1 [1 => 0 at 18:40:12; F/F as of 18:40:12/18:40:12] <condyn7t7hj>
&-T-group "Motion Off Toilet" (AND) TRUE as of 18:43:12 <grpyn7u90a>
| &-T-service Guest Toilet Sensor (350) urn:micasaverde-com:serviceId:SecuritySensor1/Tripped = 0 for ge 180s [1 => 0 at 18:40:12; T/T as of 18:40:12/18:43:12] <condyn7v4wd>
&-F-group "Motion On Hall" (AND) false as of 19:45:43 <grpyn87ow7>
| &-T-sun bet sunset+0,sunrise+0 [1605037573 => 1605037936 at 19:52:16; T/T as of 16:19:00/16:19:00] <condyn88g2u>
| &-F-service Hall Motion Sensor (325) urn:micasaverde-com:serviceId:SecuritySensor1/Tripped = 1 [1 => 0 at 19:45:43; F/F as of 19:45:43/19:45:43] <condyn87vnv>
&-T-group "Motion Off Hall" (AND) TRUE as of 19:46:13 <grpyn8b233>
| &-T-service Hall Motion Sensor (325) urn:micasaverde-com:serviceId:SecuritySensor1/Tripped = 0 for ge 30s [1 => 0 at 19:45:43; T/T as of 19:45:43/19:46:13] <condyn8b7k5>
&-F-group "Motion On Utility" (AND) false as of 16:45:07 <grpyn8hl3b>
| &-T-sun bet sunset+0,sunrise+0 [1605037573 => 1605037936 at 19:52:16; T/T as of 16:19:00/16:19:00] <condyn8i0zo>
| &-F-service Utility Sensor (345) urn:micasaverde-com:serviceId:SecuritySensor1/Tripped = 1 [1 => 0 at 16:45:07; F/F as of 16:45:07/16:45:07] <condyn8hnzc>
&-T-group "Motion Off Utility" (AND) TRUE as of 16:45:22 <grpyn8ihgl>
| &-T-service Utility Sensor (345) urn:micasaverde-com:serviceId:SecuritySensor1/Tripped = 0 for ge 15s [1 => 0 at 16:45:07; T/T as of 16:45:07/16:45:22] <condyn8iyfk>
&-?-comment "" <condypaqmtq>
&-F-group "Cinema Motion On" (AND) false as of 18:10:32 <grpypaqrwu>
| &-T-sun bet sunset+0,sunrise+0 [1605037573 => 1605037936 at 19:52:16; T/T as of 16:19:00/16:19:00] <condypasxtj>
| &-F-service Cinema Neo (390) urn:micasaverde-com:serviceId:SecuritySensor1/Tripped = 1 [1 => 0 at 18:10:32; F/F as of 18:10:32/18:10:32] <condypaqz58>
&-T-group "Motion Off" (AND) TRUE as of 18:11:02 <grpypatw65>
| &-T-service Cinema Neo (390) urn:micasaverde-com:serviceId:SecuritySensor1/Tripped = 0 for ge 30s [1 => 0 at 18:10:32; T/T as of 18:10:32/18:11:02] <condypau6pa>
| &-T-service HRM: Pioneer AV Rece (93) urn:rboer-com:serviceId:HarmonyDevice1/Command2 = PowerOff [poweroff at 11-09.19:30:56; T/T as of 11-09.19:30:56/11-09.19:30:56] <condypqpbk5>
Activity grpyn8hl3b.true
Device Utility Light (58) action urn:upnp-org:serviceId:SwitchPower1/SetTarget( newTargetValue="1" )
Activity grpyn8ihgl.true
Device Utility Light (58) action urn:upnp-org:serviceId:SwitchPower1/SetTarget( newTargetValue="0" )
Activity grpyn7t2jb.true
Device Guest Toilet (211) action urn:upnp-org:serviceId:SwitchPower1/SetTarget( newTargetValue="1" )
Activity grpypaqrwu.true
Device Table Lamps (101) action urn:upnp-org:serviceId:Dimming1/SetLoadLevelTarget( newLoadlevelTarget="3" )
Activity grpypiiwrc.true
Device Landing Light (205) action urn:upnp-org:serviceId:SwitchPower1/SetTarget( newTargetValue="1" )
Activity grpyn7u90a.true
Device Guest Toilet (211) action urn:upnp-org:serviceId:SwitchPower1/SetTarget( newTargetValue="0" )
Activity grpyn87ow7.true
Device Hall Light (207) action urn:upnp-org:serviceId:SwitchPower1/SetTarget( newTargetValue="1" )
Activity grpyr5w40e.true
Device Landing Light (205) action urn:upnp-org:serviceId:Dimming1/SetLoadLevelTarget( newLoadlevelTarget="10" )
Activity grpyn8b233.true
Device Hall Light (207) action urn:upnp-org:serviceId:SwitchPower1/SetTarget( newTargetValue="0" )
Activity grpypatw65.true
Device Table Lamps (101) action urn:upnp-org:serviceId:SwitchPower1/SetTarget( newTargetValue="0" )
Activity grpypinsyp.true
Device Landing Light (205) action urn:upnp-org:serviceId:SwitchPower1/SetTarget( newTargetValue="0" )
Events
2020-11-10 19:52:15: Reactor startup (Luup reload)
2020-11-10 19:52:15: Starting (Luup Startup/Reload)
2020-11-10 19:52:16: Sensor update starting
2020-11-10 19:52:16: Condition condyn7v4wd successfully sustained for at least 180 seconds (actual 4324)
2020-11-10 19:52:16: Condition condyn8b7k5 successfully sustained for at least 30 seconds (actual 393)
2020-11-10 19:52:16: Condition condyn8iyfk successfully sustained for at least 15 seconds (actual 11229)
2020-11-10 19:52:16: Condition condypau6pa successfully sustained for at least 30 seconds (actual 6104)
2020-11-10 19:52:16: Sensor update completed; 0.083s
Devices
Cinema Neo (390) urn:schemas-micasaverde-com:device:MotionSensor:1 (4/3); parent 1; plugin -; mfg model ; dev D_MotionSensor1.xml impl
Landing Light (205) urn:schemas-upnp-org:device:DimmableLight:1 (2/0); parent 204; plugin -; mfg model ; dev D_DimmableLight1.xml impl
Hall Motion Sensor (325) urn:schemas-micasaverde-com:device:MotionSensor:1 (4/3); parent 1; plugin -; mfg Fibaro model FGMS-001 (v3.2); dev D_MotionSensor1.xml impl
Hall Light (207) urn:schemas-upnp-org:device:DimmableLight:1 (2/0); parent 204; plugin -; mfg model ; dev D_DimmableLight1.xml impl
HRM: Pioneer AV Rece (93) urn:schemas-rboer-com:device:HarmonyDevice92_47811281:1 (3/0); parent 92; plugin -; mfg Pioneer model SC-LX57; dev D_HarmonyDevice92_47811281.xml impl
Harmony Control (92) urn:schemas-rboer-com:device:Harmony92:1 (3/0); parent 0; plugin 8066; mfg model ; dev D_Harmony92.xml impl I_Harmony.xml
Utility Switch (56) urn:schemas-upnp-org:device:BinaryLight:1 (3/0); parent 1; plugin -; mfg model ; dev D_BinaryLight1.xml impl
Guest Toilet Sensor (350) urn:schemas-micasaverde-com:device:MotionSensor:1 (4/3); parent 1; plugin -; mfg model ; dev D_MotionSensor1.xml impl
RFXtrx (204) urn:schemas-rfxcom-com:device:rfxtrx:1 (1/-1); parent 0; plugin -; mfg model RFXtrx433 at 433.92 MHz; dev D_RFXtrx.xml impl I_RFXtrx.xml
Utility Light (58) urn:schemas-upnp-org:device:BinaryLight:1 (3/0); parent 56; plugin -; mfg model ; dev D_BinaryLight1.xml impl
Switchboard Plugin (16) urn:schemas-toggledbits-com:device:Switchboard:1 (1/-1); parent 0; plugin 9194; mfg model ; dev D_Switchboard1.xml impl I_Switchboard1.xml
Table Lamps (101) urn:schemas-upnp-org:device:DimmableLight:1 (2/0); parent 16; plugin -; mfg rigpapa model Switchboard Virtual Dimmer; dev D_DimmableLight1.xml impl
Guest Toilet (211) urn:schemas-upnp-org:device:DimmableLight:1 (2/0); parent 204; plugin -; mfg model ; dev D_DimmableLight1.xml impl
ZWave (1) urn:schemas-micasaverde-com:device:ZWaveNetwork:1 (19/0); parent 0; plugin -; mfg model ; dev D_ZWaveNetwork.xml impl
Utility Sensor (345) urn:schemas-micasaverde-com:device:MotionSensor:1 (4/3); parent 1; plugin -; mfg Fibaro model FGMS-001 (v3.2); dev D_MotionSensor1.xml impl
Watches
Device #314 Motion TV & Cinema service urn:toggledbits-com:serviceId:ReactorSensor variable TestHouseMode
Device #325 Hall Motion Sensor service urn:micasaverde-com:serviceId:SecuritySensor1 variable Tripped
Device #350 Guest Toilet Sensor service urn:micasaverde-com:serviceId:SecuritySensor1 variable Tripped
Device #93 HRM: Pioneer AV Rece service urn:rboer-com:serviceId:HarmonyDevice1 variable Command2
Device #314 Motion TV & Cinema service urn:toggledbits-com:serviceId:ReactorSensor variable cdata
Device #390 Cinema Neo service urn:micasaverde-com:serviceId:SecuritySensor1 variable Tripped
Device #314 Motion TV & Cinema service urn:toggledbits-com:serviceId:ReactorSensor variable TestTime
Device #345 Utility Sensor service urn:micasaverde-com:serviceId:SecuritySensor1 variable Tripped
Special Configuration
LogEventsToFile = 1
Matsohl
November 12, 2020, 4:00pm
#5
I was actually on my way to look at your logs this evening. Good that I haven’t come to it yet …
Haha, it clicked when I posted the logic summary or shortly after anyway, thanks for giving me a clue and your time
