You need to either fix the non-detected devices, or remove them from your Reactors
Once that’s done, a Luup reload will start Reactor back up.
C
C
I had that yesterday (as part of my Vera upgrade process
All reactor sensors were out. So what you need to do:
And after all of this make new backup of Reactor config.
Hope this helps.
Hmmm… You guys are mixing concepts here.
To be clear: “Safety lockout” is NOT the result of missing devices or other configuration problems with any ReactorSensor.
Reactor doesn’t stop operating for trivial problems like a missing device. Safety lockout occurs when and only when your Vera reboots or reloads more than 10 times in 15 minutes (by default).
The yellow warning triangle is used for multiple purposes to draw your attention. Missing devices is only one of them. There is a long list of others, including Safety Lockout. You need to look at the other messages and clues in order to figure out why the triangle is being presented.
So:
rs state variable on the Reactor master device to “0” and reload Luup.did i not link to the correct forum post with safety lockout advice?
You did well. I’m going to move this whole thread there, in fact.
Hi all,
Iam a huge fan of reactor but after the last update (via tools/Update Device Information Database) I can’t use it anymore.
On my main reactor I see the message ‘Safety Lockout!’ and when I click on it I see a red ‘Reactor.Can’t Detect Device message’.
On the real reactors I get the red ‘can’t detect device’ message.
Can you tell me what I can do so I can use all my reactors again? I hope someone can help.
Kind regards
Jeroen
