Reactor is initiating the wrong set of Actions when testing a variable.
I need to test a device variable for a value greater than zero, and use Reactor to initiate a set of Actions, depending on whether the result is true or false.
To test the Reactor, I use a MultiString variable, “Misc info, variable 4” to simulate the device variable, and test if its value is above zero. I use actions under Reactor Activities to set 2 Switchboard Plugin virtual devices, “Charging” and “Not Charging”, to show the result.
If the test is TRUE (i.e. the tested level is above zero), “Charging” is switched on.
If the test is FALSE (i.e. the tested level is zero), “Not Charging” is switched on.
What I find is that the Activity for TRUE is run in both cases, whether the result is TRUE or FALSE.
Can anyone spot what I’ve done wrong?
The Logic Summary output is below:
*************************************************** REACTOR LOGIC SUMMARY REPORT ***************************************************
Version: 3.8-20262 config 20190 cdata 20045 ui 20190 pluginDevice 285 LuaXP not loaded
System: Vera version 1.7.5186 (7.31) on Sercomm G450 ID 36 (Vera Plus); loadtime 1754657412/1754657430; systemReady 1754657435
Env: Lua 5.1; JSON dkjson 1.2; UnsafeLua=nil/true
Local time: 2025-08-08T16:09:35+0100; DST=1; Royston, England United Kingdom; formats %d/%m/%Y %H:%M:%S
House mode: plugin 1; system 1; tracking off
Sun data: { "source": "int", "civdawn": 1754625065, "nautdawn": 1754621695, "sunset": 1754682603, "nautdusk": 1754688481, "stamp": 2025220, "latitude": 53.6, "astrodusk": 1754693250, "longitude": -1.45, "civdusk": 1754685111, "astrodawn": 1754616926, "sunrise": 1754627573 }
Geofence: not running
RS: 1754588951,1754643326,1754643372,1754643457,1754643525,1754655498,1754655624,1754656289,1754657350,1754657430
NS: 1752532920:D,1752574020:U,1753752485:D,1753754040:U,1753839720:D,1753840080:U,1754007480:D,1754007660:U,1754034245:D,1754034480:U
2 Test for current (#534) armed
Version 20045.13 08/08/25 16:07:43
Message/status: Not tripped
Condition group "Charger drawing power" (AND) false as of 16:04:22 <root>
&-F-service Misc info (219) urn:upnp-org:serviceId:VContainer1/Variable4 > 0 [0.00 => 0 at 16:07:43; F/F as of 16:04:22/16:04:22] <cond0>
Activity root.false
Device NOT charging (531) action urn:upnp-org:serviceId:SwitchPower1/SetTarget( newTargetValue="1" )
Activity root.true
Device Charging (526) action urn:upnp-org:serviceId:SwitchPower1/SetTarget( newTargetValue="1" )
Events
2025-08-08 13:55:51: Starting "root.false" group 1
2025-08-08 13:55:51: Activity "root.false" finished
2025-08-08 13:55:51: Stopping activity "root.false"
2025-08-08 13:56:36: { dev=534, action="RunScene", options={ stopPriorScenes=false, forceReactorScenes=true, contextDevice=534 }, sceneId="root.true", event="action", scene="root.true" }
2025-08-08 13:56:36: Launching scene/activity root.true
2025-08-08 13:56:36: Starting "root.true" group 1
2025-08-08 13:56:36: Activity "root.true" finished
2025-08-08 13:56:36: Stopping activity "root.true"
2025-08-08 13:57:29: Configuration changed!
2025-08-08 13:57:29: Sensor update starting
2025-08-08 13:57:29: Condition cond0 test state changed from false to true
2025-08-08 13:57:29: Condition cond0 evaluation state changed from false to true
2025-08-08 13:57:29: Group Charger drawing power test state changed from false to true
2025-08-08 13:57:29: Group Charger drawing power evaluation state changed from false to true
2025-08-08 13:57:29: Preparing Charger drawing power.true (root.true) activity
2025-08-08 13:57:29: Launching scene/activity root.true
2025-08-08 13:57:30: Starting "root.true" group 1
2025-08-08 13:57:30: Activity "root.true" finished
2025-08-08 13:57:30: Stopping activity "root.true"
2025-08-08 13:57:30: Changing RS tripped state to true
2025-08-08 13:57:30: Sensor update completed; 0.040s
2025-08-08 13:57:59: { dev=534, action="RunScene", options={ stopPriorScenes=false, forceReactorScenes=true, contextDevice=534 }, sceneId="root.true", event="action", scene="root.true" }
2025-08-08 13:57:59: Launching scene/activity root.true
2025-08-08 13:57:59: Starting "root.true" group 1
2025-08-08 13:57:59: Activity "root.true" finished
2025-08-08 13:57:59: Stopping activity "root.true"
2025-08-08 14:01:17: Configuration changed!
2025-08-08 14:01:17: Sensor update starting
2025-08-08 14:01:17: Sensor update completed; 0.027s
2025-08-08 14:01:37: { dev=534, action="RunScene", options={ stopPriorScenes=false, forceReactorScenes=true, contextDevice=534 }, sceneId="root.true", event="action", scene="root.true" }
2025-08-08 14:01:37: Launching scene/activity root.true
2025-08-08 14:01:37: Starting "root.true" group 1
2025-08-08 14:01:37: Activity "root.true" finished
2025-08-08 14:01:37: Stopping activity "root.true"
2025-08-08 15:29:47: Configuration changed!
2025-08-08 15:29:47: Sensor update starting
2025-08-08 15:29:47: Condition cond0 test state changed from true to false
2025-08-08 15:29:47: Condition cond0 evaluation state changed from true to false
2025-08-08 15:29:47: Group Charger drawing power test state changed from true to false
2025-08-08 15:29:47: Group Charger drawing power evaluation state changed from true to false
2025-08-08 15:29:47: Preparing Charger drawing power.false (root.false) activity
2025-08-08 15:29:47: Launching scene/activity root.false
2025-08-08 15:29:47: Starting "root.false" group 1
2025-08-08 15:29:47: Activity "root.false" finished
2025-08-08 15:29:47: Stopping activity "root.false"
2025-08-08 15:29:47: Changing RS tripped state to false
2025-08-08 15:29:47: Sensor update completed; 0.085s
2025-08-08 15:35:42: Configuration changed!
2025-08-08 15:35:42: Sensor update starting
2025-08-08 15:35:42: Sensor update completed; 0.021s
2025-08-08 15:37:05: Configuration changed!
2025-08-08 15:37:05: Sensor update starting
2025-08-08 15:37:05: Sensor update completed; 0.021s
2025-08-08 16:03:21: { dev=534, action="RunScene", options={ stopPriorScenes=false, forceReactorScenes=true, contextDevice=534 }, sceneId="root.true", event="action", scene="root.true" }
2025-08-08 16:03:21: Launching scene/activity root.true
2025-08-08 16:03:21: Starting "root.true" group 1
2025-08-08 16:03:21: Activity "root.true" finished
2025-08-08 16:03:21: Stopping activity "root.true"
2025-08-08 16:03:46: Device Misc info (#219) urn:upnp-org:serviceId:VContainer1/Variable4 changed from "0" to "5"
2025-08-08 16:03:46: Sensor update starting
2025-08-08 16:03:46: Condition cond0 test state changed from false to true
2025-08-08 16:03:46: Condition cond0 evaluation state changed from false to true
2025-08-08 16:03:46: Group Charger drawing power test state changed from false to true
2025-08-08 16:03:46: Group Charger drawing power evaluation state changed from false to true
2025-08-08 16:03:46: Preparing Charger drawing power.true (root.true) activity
2025-08-08 16:03:46: Launching scene/activity root.true
2025-08-08 16:03:46: Starting "root.true" group 1
2025-08-08 16:03:46: Activity "root.true" finished
2025-08-08 16:03:46: Stopping activity "root.true"
2025-08-08 16:03:46: Changing RS tripped state to true
2025-08-08 16:03:46: Sensor update completed; 0.073s
2025-08-08 16:04:00: { dev=534, action="RunScene", options={ stopPriorScenes=false, forceReactorScenes=true, contextDevice=534 }, sceneId="root.true", event="action", scene="root.true" }
2025-08-08 16:04:00: Launching scene/activity root.true
2025-08-08 16:04:00: Starting "root.true" group 1
2025-08-08 16:04:00: Activity "root.true" finished
2025-08-08 16:04:00: Stopping activity "root.true"
2025-08-08 16:04:22: Device Misc info (#219) urn:upnp-org:serviceId:VContainer1/Variable4 changed from "5" to "0"
2025-08-08 16:04:22: Sensor update starting
2025-08-08 16:04:22: Condition cond0 test state changed from true to false
2025-08-08 16:04:22: Condition cond0 evaluation state changed from true to false
2025-08-08 16:04:22: Group Charger drawing power test state changed from true to false
2025-08-08 16:04:22: Group Charger drawing power evaluation state changed from true to false
2025-08-08 16:04:22: Preparing Charger drawing power.false (root.false) activity
2025-08-08 16:04:22: Launching scene/activity root.false
2025-08-08 16:04:22: Starting "root.false" group 1
2025-08-08 16:04:22: Activity "root.false" finished
2025-08-08 16:04:22: Stopping activity "root.false"
2025-08-08 16:04:22: Changing RS tripped state to false
2025-08-08 16:04:22: Sensor update completed; 0.070s
2025-08-08 16:05:48: Configuration changed!
2025-08-08 16:05:48: Sensor update starting
2025-08-08 16:05:48: Sensor update completed; 0.008s
2025-08-08 16:06:39: { dev=534, action="RunScene", options={ stopPriorScenes=false, forceReactorScenes=true, contextDevice=534 }, sceneId="root.true", event="action", scene="root.true" }
2025-08-08 16:06:39: Launching scene/activity root.true
2025-08-08 16:06:39: Starting "root.true" group 1
2025-08-08 16:06:39: Activity "root.true" finished
2025-08-08 16:06:39: Stopping activity "root.true"
2025-08-08 16:07:43: Configuration changed!
2025-08-08 16:07:43: Sensor update starting
2025-08-08 16:07:43: Sensor update completed; 0.012s
Devices
Misc info (219) urn:schemas-upnp-org:device:VContainer:1 (0/-1); parent 0; plugin 8231; mfg model ; dev D_MString.xml impl I_MString.xml
Switchboard Plugin (8) urn:schemas-toggledbits-com:device:Switchboard:1 (1/-1); parent 0; plugin 9194; mfg model ; dev D_Switchboard1.xml impl I_Switchboard1.xml
Charging (526) urn:schemas-upnp-org:device:BinaryLight:1 (3/1); parent 8; plugin -; mfg rigpapa model Switchboard Virtual Binary Switch; dev D_BinaryLight1.xml impl
NOT charging (531) urn:schemas-upnp-org:device:BinaryLight:1 (3/1); parent 8; plugin -; mfg rigpapa model Switchboard Virtual Binary Switch; dev D_BinaryLight1.xml impl
Watches
Device #534 2 Test for current service urn:toggledbits-com:serviceId:ReactorSensor variable TestTime
Device #534 2 Test for current service urn:toggledbits-com:serviceId:ReactorSensor variable cdata
Device #534 2 Test for current service urn:toggledbits-com:serviceId:ReactorSensor variable TestHouseMode
Device #517 EV Charger service urn:micasaverde-com:serviceId:EnergyMetering1 variable Amps
Device #219 Misc info service urn:upnp-org:serviceId:VContainer1 variable Variable4
