Hmm, Im still having issues with Reactor sensors randomly not working - this one usually works fine but in the past 24 hrs 2 separate parts have tripped but the Activity has not worked.
Yesterday the first part fired (turning on the Downstairs AC) when it should of but did not change the set-point when the temp exceeded 30c (i had to do it manually).
Today the first part has not fired despite all conditions being met. You can see the AC is not in CoolOn mode, but in Off mode.
This logic had been working just fine until 7.3x - the only changes I’ve made recently are to the set-points.
*************************************************** REACTOR LOGIC SUMMARY REPORT ***************************************************
Version: 3.4 config 19226 cdata 19082 ui 19237 pluginDevice 120
System: Vera version 1.7.4903 on Sercomm G450; loadtime 1578799664; systemReady 1578799690; Lua 5.1; JSON dkjson 2.5+LPeg
Local time: 2020-01-14T11:22:00+1100; DST=1; Kilsyth, Victoria Australia
House mode: plugin 1; system 1; tracking on
Sun data: {"stamp":2020014,"civdawn":1578940849,"nautdawn":1578938584,"sunset":1578994977,"nautdusk":1578999070,"latitude":-37.804519,"astrodusk":1579001589,"longitude":145.331965,"civdusk":1578996805,"astrodawn":1578936065,"sunrise":1578942677}
Geofence: not running
Downstairs Cooling (#221) tripped
Version 19082.148 01/12/20 16:43:29
Message/status: Tripped
Condition group "Cooling All" (OR) TRUE as of 11:16:14 <root>
|-T-group "Cooling On" (AND) TRUE as of 11:16:14 <grpdes4yia>
| &-T-housemode in 1,2 [3 => 1 at 06:00:00; T/T as of 06:00:00/06:00:00] <condc0v1zdx>
| &-T-service WU - Conditions (368) urn:toggledbits-com:serviceId:SiteSensor1/Value2 >= 26 [25 => 26 at 11:16:14; T/T as of 11:16:14/11:16:14] <condc0v09ig>
| &-T-service Rumpus Room (354) urn:upnp-org:serviceId:HVAC_UserOperatingMode1/ModeStatus = Off [coolon => off at 21:17:12; T/T as of 21:17:12/21:17:12] <condc0vqbez>
| &-T-service Rumpus Room (354) urn:upnp-org:serviceId:TemperatureSensor1/CurrentTemperature >= 23 [22 => 23 at 10:13:12; T/T as of 10:13:12/10:13:12] <condc0v2fm5>
|-F-group "Outside Tmp -30" (AND) false as of 20:01:27 <grpleae6xw>
| &-T-housemode in 1,2 [3 => 1 at 06:00:00; T/T as of 06:00:00/06:00:00] <condleaeswf>
| &-T-service WU - Conditions (368) urn:toggledbits-com:serviceId:SiteSensor1/Value2 < 30 [25 => 26 at 11:16:14; T/T as of 20:01:14/20:01:14] <condleaf30i>
| &-F-service Rumpus Room (354) urn:upnp-org:serviceId:HVAC_UserOperatingMode1/ModeStatus = CoolOn [coolon => off at 21:17:12; F/F as of 21:17:12/21:17:12] <condleagbj9>
| &-T-service Rumpus Room (354) urn:upnp-org:serviceId:TemperatureSetpoint1/CurrentSetpoint <> 23 [23 => 0 at 21:17:23; T/T as of 21:17:23/21:17:23] <condleajhkl>
|-F-group "Outside Tmp 30+" (AND) false as of 18:13:10 <grpdes730z>
| &-T-housemode in 1,2 [3 => 1 at 06:00:00; T/T as of 06:00:00/06:00:00] <conddes8cgx>
| &-F-service WU - Conditions (368) urn:toggledbits-com:serviceId:SiteSensor1/Value2 >= 30 [25 => 26 at 11:16:14; F/F as of 20:01:14/20:01:14] <conddes90bd>
| &-T-service WU - Conditions (368) urn:toggledbits-com:serviceId:SiteSensor1/Value2 < 36 [25 => 26 at 11:16:14; T/T as of 01-10.08:09:05/01-10.08:09:05] <conddesbnyi>
| &-F-service Rumpus Room (354) urn:upnp-org:serviceId:HVAC_UserOperatingMode1/ModeStatus = CoolOn [coolon => off at 21:17:12; F/F as of 21:17:12/21:17:12] <conddes9ysx>
| &-T-service Rumpus Room (354) urn:upnp-org:serviceId:TemperatureSetpoint1/CurrentSetpoint <> 22 [23 => 0 at 21:17:23; T/T as of 20:01:27/20:01:27] <condkoddyt0>
|-F-group "Outside Tmp 36+" (AND) false as of 01-10.08:09:05 <grpdescsml>
| &-T-housemode in 1,2 [3 => 1 at 06:00:00; T/T as of 06:00:00/06:00:00] <conddescv6g>
| &-F-service WU - Conditions (368) urn:toggledbits-com:serviceId:SiteSensor1/Value2 >= 36 [25 => 26 at 11:16:14; F/F as of 01-10.08:09:05/01-10.08:09:05] <conddesdedp>
| &-F-service Rumpus Room (354) urn:upnp-org:serviceId:HVAC_UserOperatingMode1/ModeStatus = CoolOn [coolon => off at 21:17:12; F/F as of 21:17:12/21:17:12] <conddesed4b>
| &-T-service Rumpus Room (354) urn:upnp-org:serviceId:TemperatureSetpoint1/CurrentSetpoint <> 20 [23 => 0 at 21:17:23; T/T as of 01-10.08:09:05/01-10.08:09:05] <condkodf5sm>
|-F-group "Cooling Off" (OR) false as of 21:17:12 <grpdesm297>
| |-F-group "Normal Off" (AND) false as of 01-10.16:07:59 <grpdesnrth>
| | &-T-housemode in 1,2 [3 => 1 at 06:00:00; T/T as of 06:00:00/06:00:00] <conddesma3g>
| | &-F-service Rumpus Room (354) urn:upnp-org:serviceId:HVAC_UserOperatingMode1/ModeStatus = CoolOn [coolon => off at 21:17:12; F/F as of 21:17:12/21:17:12] <conddesmgfi>
| | &-F-service Nest Thermostat DS (7) urn:upnp-org:serviceId:TemperatureSensor1/CurrentTemperature <= 22 [22 => 23 at 11:12:28; F/F as of 11:12:28/11:12:28] <condjknopy4>
| | &-F-service WU - Conditions (368) urn:toggledbits-com:serviceId:SiteSensor1/Value2 <= 21 [25 => 26 at 11:16:14; F/F as of 10:11:14/10:11:14] <conddespwyd>
| |-F-group "Night Off" (AND) false as of 21:17:12 <grpdesnyab>
| | &-F-housemode in 3,4 [3 => 1 at 06:00:00; F/F as of 06:00:00/06:00:00] <conddesrq67>
| | &-F-service Rumpus Room (354) urn:upnp-org:serviceId:HVAC_UserOperatingMode1/ModeStatus = CoolOn [coolon => off at 21:17:12; F/F as of 21:17:12/21:17:12] <conddess01h>
Activity grpdescsml.true
Delay 10 inline
Device Rumpus Room (354) action urn:upnp-org:serviceId:TemperatureSetpoint1_Cool/SetCurrentSetpoint( NewCurrentSetpoint="20" )
Activity grpleae6xw.true
Delay 10 inline
Device Rumpus Room (354) action urn:upnp-org:serviceId:TemperatureSetpoint1_Cool/SetCurrentSetpoint( NewCurrentSetpoint="23" )
Activity grpdes4yia.true
Device Rumpus Room (354) action urn:upnp-org:serviceId:HVAC_UserOperatingMode1/SetModeTarget( NewModeTarget="CoolOn", NewCoolSetpoint="23" )
Delay 10 inline
Activity grpdesm297.true
Delay 10 inline
Device Rumpus Room (354) action urn:upnp-org:serviceId:HVAC_UserOperatingMode1/SetModeTarget( NewModeTarget="Off" )
Delay 10 inline
Activity grpdes730z.true
Delay 10 inline
Device Rumpus Room (354) action urn:upnp-org:serviceId:TemperatureSetpoint1_Cool/SetCurrentSetpoint( NewCurrentSetpoint="22" )
Events
01/14/20 06:00:00 condchange: newState=true, cond=conddescv6g, oldState=false
01/14/20 06:00:00 evalchange: newState=true, cond=conddescv6g, oldState=false
01/14/20 06:00:00 condchange: newState=true, cond=conddesma3g, oldState=false
01/14/20 06:00:00 evalchange: newState=true, cond=conddesma3g, oldState=false
01/14/20 06:00:00 condchange: newState=false, cond=conddesrq67, oldState=true
01/14/20 06:00:00 evalchange: newState=false, cond=conddesrq67, oldState=true
01/14/20 06:33:09 devicewatch: device=354, old="23", name=Rumpus Room, var=urn:upnp-org:serviceId:TemperatureSensor1/CurrentTemperature, new="22"
01/14/20 06:33:09 condchange: newState=false, cond=condc0v2fm5, oldState=true
01/14/20 06:33:09 evalchange: newState=false, cond=condc0v2fm5, oldState=true
01/14/20 08:01:14 devicewatch: device=368, old="17", name=WU - Conditions, var=urn:toggledbits-com:serviceId:SiteSensor1/Value2, new="18"
01/14/20 08:51:15 devicewatch: device=368, old="18", name=WU - Conditions, var=urn:toggledbits-com:serviceId:SiteSensor1/Value2, new="19"
01/14/20 09:13:10 devicewatch: device=354, old="22", name=Rumpus Room, var=urn:upnp-org:serviceId:TemperatureSensor1/CurrentTemperature, new="23"
01/14/20 09:13:10 condchange: newState=true, cond=condc0v2fm5, oldState=false
01/14/20 09:13:10 evalchange: newState=true, cond=condc0v2fm5, oldState=false
01/14/20 09:21:14 devicewatch: device=368, old="19", name=WU - Conditions, var=urn:toggledbits-com:serviceId:SiteSensor1/Value2, new="20"
01/14/20 09:23:09 devicewatch: device=354, old="23", name=Rumpus Room, var=urn:upnp-org:serviceId:TemperatureSensor1/CurrentTemperature, new="22"
01/14/20 09:23:09 condchange: newState=false, cond=condc0v2fm5, oldState=true
01/14/20 09:23:09 evalchange: newState=false, cond=condc0v2fm5, oldState=true
01/14/20 09:28:09 devicewatch: device=354, old="22", name=Rumpus Room, var=urn:upnp-org:serviceId:TemperatureSensor1/CurrentTemperature, new="23"
01/14/20 09:28:09 condchange: newState=true, cond=condc0v2fm5, oldState=false
01/14/20 09:28:09 evalchange: newState=true, cond=condc0v2fm5, oldState=false
01/14/20 09:51:14 devicewatch: device=368, old="20", name=WU - Conditions, var=urn:toggledbits-com:serviceId:SiteSensor1/Value2, new="21"
01/14/20 09:58:09 devicewatch: device=354, old="23", name=Rumpus Room, var=urn:upnp-org:serviceId:TemperatureSensor1/CurrentTemperature, new="22"
01/14/20 09:58:09 condchange: newState=false, cond=condc0v2fm5, oldState=true
01/14/20 09:58:09 evalchange: newState=false, cond=condc0v2fm5, oldState=true
01/14/20 10:11:14 devicewatch: device=368, old="21", name=WU - Conditions, var=urn:toggledbits-com:serviceId:SiteSensor1/Value2, new="22"
01/14/20 10:11:14 condchange: newState=false, cond=conddespwyd, oldState=true
01/14/20 10:11:14 evalchange: newState=false, cond=conddespwyd, oldState=true
01/14/20 10:13:12 devicewatch: device=354, old="22", name=Rumpus Room, var=urn:upnp-org:serviceId:TemperatureSensor1/CurrentTemperature, new="23"
01/14/20 10:13:12 condchange: newState=true, cond=condc0v2fm5, oldState=false
01/14/20 10:13:12 evalchange: newState=true, cond=condc0v2fm5, oldState=false
01/14/20 10:41:15 devicewatch: device=368, old="22", name=WU - Conditions, var=urn:toggledbits-com:serviceId:SiteSensor1/Value2, new="23"
01/14/20 11:01:14 devicewatch: device=368, old="23", name=WU - Conditions, var=urn:toggledbits-com:serviceId:SiteSensor1/Value2, new="24"
01/14/20 11:11:14 devicewatch: device=368, old="24", name=WU - Conditions, var=urn:toggledbits-com:serviceId:SiteSensor1/Value2, new="25"
01/14/20 11:12:28 devicewatch: device=7, old="22", name=Nest Thermostat DS, var=urn:upnp-org:serviceId:TemperatureSensor1/CurrentTemperature, new="23"
01/14/20 11:12:28 condchange: newState=false, cond=condjknopy4, oldState=true
01/14/20 11:12:28 evalchange: newState=false, cond=condjknopy4, oldState=true
01/14/20 11:16:14 devicewatch: device=368, old="25", name=WU - Conditions, var=urn:toggledbits-com:serviceId:SiteSensor1/Value2, new="26"
01/14/20 11:16:14 condchange: newState=true, cond=condc0v09ig, oldState=false
01/14/20 11:16:14 evalchange: newState=true, cond=condc0v09ig, oldState=false
01/14/20 11:16:14 condchange: newState=true, cond=grpdes4yia, oldState=false
01/14/20 11:16:14 evalchange: newState=true, cond=grpdes4yia, oldState=false
01/14/20 11:16:14 condchange: newState=true, cond=root, oldState=false
01/14/20 11:16:14 evalchange: newState=true, cond=root, oldState=false
01/14/20 11:16:14 startscene: scene=grpdes4yia.true, sceneName=grpdes4yia.true
01/14/20 11:16:14 runscene: scene=grpdes4yia.true, sceneName=grpdes4yia.true, group=1, notice=Starting scene group 1
01/14/20 11:16:17 runscene: scene=grpdes4yia.true, sceneName=grpdes4yia.true, group=2, notice=Scene delay until 11:16:27
01/14/20 11:16:17 sensorstate: state=true
01/14/20 11:16:27 runscene: scene=grpdes4yia.true, sceneName=grpdes4yia.true, group=2, notice=Starting scene group 2
01/14/20 11:16:27 endscene: scene=grpdes4yia.true, sceneName=grpdes4yia.true
Devices
WU - Conditions (368) urn:schemas-toggledbits-com:device:SiteSensor:1 (4/0); parent 0; plugin 8942
Honeywell Lyric (353) urn:schemas-micasaverde-com:device:HoneywellLyric:1 (0/-1); parent 0; plugin 8768
Vera Connect Works W (5) urn:schemas-micasaverde-com:device:VeraConnectWWN:1 (0/-1); parent 0; plugin 8151
Nest Thermostat DS (7) urn:schemas-upnp-org:device:HVAC_ZoneThermostat:1 (5/1); parent 5; plugin -
Rumpus Room (354) urn:schemas-upnp-org:device:HVAC_ZoneThermostat:1 (5/1); parent 353; plugin -
