If you are pasting this report into the Vera forums, please include ALL lines below--please do not edit/omit/redact!
*************************************************** REACTOR LOGIC SUMMARY REPORT ***************************************************
Version: 2.5 config 206 pluginDevice 127
System: Vera Sercomm G450 firmware 1.7.4001; Lua 5.1
Local time: 2019-04-24T10:16:17-0600, DST=1
House mode: tracking on; current mode 2
Sun data:
Geofence: not running
Front Door AutoLock (#128)
Version 19012.1555873326 04/21/19 13:02:06
Message/status: Not tripped
Group #1: grpc0x7v6v; false as of 04-18.18:42:23 <grpc0x7v6v>
=T (service) Front Door Sensor (37) urn:micasaverde-com:serviceId:SecuritySensor1/Tripped = 0 [true/true as of 08:10:27/08:10:27; 1 => 0 at 08:10:27] <condc0x7v6w>
=f (service) Front Door Lock (58) urn:micasaverde-com:serviceId:DoorLock1/Status = 0 for ge 90s after condc0x7v6w [false/false as of 10:15:16/04-18.18:42:23; 0 => 1 at 10:15:16] <condc0xphex>
Trip Actions
Device 58 (Front Door Lock) action urn:micasaverde-com:serviceId:DoorLock1/SetTarget( newTargetValue=1 )
Untrip Actions (none)
Events
04/23/19 19:21:18 condchange: newState=true, cond=condc0x7v6w, oldState=false
04/23/19 19:21:18 evalchange: newState=true, cond=condc0x7v6w, oldState=false
04/23/19 19:45:09 devicewatch: device=37, old="0", name=Front Door Sensor, var=urn:micasaverde-com:serviceId:SecuritySensor1/Tripped, new="1"
04/23/19 19:45:10 condchange: newState=false, cond=condc0x7v6w, oldState=true
04/23/19 19:45:10 evalchange: newState=false, cond=condc0x7v6w, oldState=true
04/23/19 19:47:50 devicewatch: device=37, old="1", name=Front Door Sensor, var=urn:micasaverde-com:serviceId:SecuritySensor1/Tripped, new="0"
04/23/19 19:47:51 condchange: newState=true, cond=condc0x7v6w, oldState=false
04/23/19 19:47:51 evalchange: newState=true, cond=condc0x7v6w, oldState=false
04/23/19 19:58:40 devicewatch: device=37, old="0", name=Front Door Sensor, var=urn:micasaverde-com:serviceId:SecuritySensor1/Tripped, new="1"
04/23/19 19:58:41 condchange: newState=false, cond=condc0x7v6w, oldState=true
04/23/19 19:58:41 evalchange: newState=false, cond=condc0x7v6w, oldState=true
04/23/19 19:58:48 devicewatch: device=37, old="1", name=Front Door Sensor, var=urn:micasaverde-com:serviceId:SecuritySensor1/Tripped, new="0"
04/23/19 19:58:49 condchange: newState=true, cond=condc0x7v6w, oldState=false
04/23/19 19:58:49 evalchange: newState=true, cond=condc0x7v6w, oldState=false
04/23/19 20:04:02 devicewatch: device=37, old="0", name=Front Door Sensor, var=urn:micasaverde-com:serviceId:SecuritySensor1/Tripped, new="1"
04/23/19 20:04:03 condchange: newState=false, cond=condc0x7v6w, oldState=true
04/23/19 20:04:03 evalchange: newState=false, cond=condc0x7v6w, oldState=true
04/23/19 20:04:05 devicewatch: device=37, old="1", name=Front Door Sensor, var=urn:micasaverde-com:serviceId:SecuritySensor1/Tripped, new="0"
04/23/19 20:04:06 condchange: newState=true, cond=condc0x7v6w, oldState=false
04/23/19 20:04:06 evalchange: newState=true, cond=condc0x7v6w, oldState=false
04/23/19 23:05:49 action: action=Trip
04/23/19 23:05:49 sensorstate: state=true
04/23/19 23:05:49 startscene: scene=root.true, sceneName=root.true
04/23/19 23:05:49 runscene: scene=root.true, sceneName=root.true, notice=Starting scene group 1
04/23/19 23:05:49 endscene: scene=root.true, sceneName=root.true
04/23/19 23:05:52 devicewatch: device=58, old="0", name=Front Door Lock, var=urn:micasaverde-com:serviceId:DoorLock1/Status, new="1"
04/23/19 23:05:53 condchange: newState=false, cond=condc0xphex, oldState=true
04/23/19 23:05:53 sensorstate: state=false
04/24/19 07:16:58 devicewatch: device=58, old="1", name=Front Door Lock, var=urn:micasaverde-com:serviceId:DoorLock1/Status, new="0"
04/24/19 07:16:59 condchange: newState=true, cond=condc0xphex, oldState=false
04/24/19 07:17:00 devicewatch: device=37, old="0", name=Front Door Sensor, var=urn:micasaverde-com:serviceId:SecuritySensor1/Tripped, new="1"
04/24/19 07:17:01 condchange: newState=false, cond=condc0x7v6w, oldState=true
04/24/19 07:17:01 evalchange: newState=false, cond=condc0x7v6w, oldState=true
04/24/19 07:17:03 devicewatch: device=37, old="1", name=Front Door Sensor, var=urn:micasaverde-com:serviceId:SecuritySensor1/Tripped, new="0"
04/24/19 07:17:04 condchange: newState=true, cond=condc0x7v6w, oldState=false
04/24/19 07:17:04 evalchange: newState=true, cond=condc0x7v6w, oldState=false
04/24/19 07:19:38 devicewatch: device=37, old="0", name=Front Door Sensor, var=urn:micasaverde-com:serviceId:SecuritySensor1/Tripped, new="1"
04/24/19 07:19:39 condchange: newState=false, cond=condc0x7v6w, oldState=true
04/24/19 07:19:39 evalchange: newState=false, cond=condc0x7v6w, oldState=true
04/24/19 07:19:41 devicewatch: device=37, old="1", name=Front Door Sensor, var=urn:micasaverde-com:serviceId:SecuritySensor1/Tripped, new="0"
04/24/19 07:19:42 condchange: newState=true, cond=condc0x7v6w, oldState=false
04/24/19 07:19:42 evalchange: newState=true, cond=condc0x7v6w, oldState=false
04/24/19 08:10:23 devicewatch: device=37, old="0", name=Front Door Sensor, var=urn:micasaverde-com:serviceId:SecuritySensor1/Tripped, new="1"
04/24/19 08:10:24 condchange: newState=false, cond=condc0x7v6w, oldState=true
04/24/19 08:10:24 evalchange: newState=false, cond=condc0x7v6w, oldState=true
04/24/19 08:10:26 devicewatch: device=37, old="1", name=Front Door Sensor, var=urn:micasaverde-com:serviceId:SecuritySensor1/Tripped, new="0"
04/24/19 08:10:27 condchange: newState=true, cond=condc0x7v6w, oldState=false
04/24/19 08:10:27 evalchange: newState=true, cond=condc0x7v6w, oldState=false
04/24/19 10:15:15 devicewatch: device=58, old="0", name=Front Door Lock, var=urn:micasaverde-com:serviceId:DoorLock1/Status, new="1"
04/24/19 10:15:16 condchange: newState=false, cond=condc0xphex, oldState=true
Startup Lua:
1:
2:
3:
4:
5:
6:
7:
