Reactor not finding rooms, nc. No Room
Thought I’d have deeper look into Reactor but stuck a hurdle in so far that Reactor sensors that I create are not being saved to rooms.
This creates the problem that I can’t access the Group State as the sensor can’t be found even though it exists. Is this a Reactor Bug?
Did you hard refresh your browser after creating the ReactorSensors?
Sure did, never forgot how to do the Vera Tango.
A hard reboot did the trick.
Hey Patrick, I like it. Never had an indepth look before but I’m impressed.
Shout you a couple of beers when the exchange rate improves…(take it as a IOU in the meantime).
What firmware are you running? I’m noticing a pattern in the 7.30/31 family that it does a terrible job of maintaining sync… something subtle is broken in the handling of user_data…
7.30
Really don’t see the benefit of going to 7.31, I’m sure you’re onto something but is it worth the effort?
I have all running. Really 7.31 is quite stable for me. I don’t have most of the issues other seem to have. But this loss of sync on occasion does stand out. Finding it will prevent nuisances for all, so I’m digging…
