Reactor 2.4 Hotfixes
This post is about current hot-fix releases for Reactor 2.4. Hotfixes address issues experienced in the wild that need an immediate update to resolve. Please check through the list of issues reported below, and apply the fix/patch documented. Hotfixes never contain new features or changes other the fix for the immediate, reported problem.
How to Hotfix Your System
Vera users can apply hotfix patches by downloading the file(s) needed from the links provided. The procedure is as follows:
  • Download the file by right-clicking on the filename/link and choosing “Save Link As…”. Do not just left-click the link and copy-paste the contents into any editor. Make sure that when asked for the save filename, the file is named exactly as shown–do not add or allow any additional or changed suffixes (“.txt”, etc.).
  • Upload the file(s) to your Vera using the uploader at Apps > Develop apps > Luup files . If you are uploading multiple files, you should turn off the “Restart Luup after upload” checkbox until the last file, then turn it back on for that one. If you forget, no problem, just turn the checkbox on and upload the last file again, it won’t hurt anything.
  • Do a full cache-flush/reload of your browser, usually CTRL-F5 for Chrome/Windows, SHIFT-F5 for Firefox/Windows, and rumored to be CMD+SHIFT+R on Macs.
openLuup/AltUI users can quickly apply all hotfixes by going to the “Plugins” page, entering “hotfix” in the version field and clicking the update icon.
The Current Hotfix Files – Apply to version 2.4 ONLY
J_ReactorSensor_UI7.js (recommended only for users experiencing symptoms described below)
  • 19094-01: Fixes an issue with interval condition parameters not saving correctly, resulting in a fixed one minute interval on new interval conditions, or the inability to change the interval on existing interval conditions.
Thanks Patrick, will give it a try and let you know! Cheers!
