Wow…you guys are amazing with this alarm plugin. I don’t have any experience with coding or alarms but I thought I would give this a try knowing I will be a bit over my head. Just reading through this forum I have managed to get my NX485/NX-8 talking with vera (I think). I now get hung up in the Lua startup. I have found two different specs on the nx584 settings _10/12/10 and 12/22/10. I have tried both settings (although my locations are different because I am using the nx8 and nx584). My NX584 settings currently match the post from 12/22.The log up to the hangup is as follows:
50 08/14/11 22:30:22.223 luup_log:17: Initializing Caddx NX-584 <0x402>
50 08/14/11 22:30:22.226 luup_log:17: Sending message and waiting for response: 0x21 Interface Configuration Request <0x402>
50 08/14/11 22:30:22.228 luup_log:17: Message: Outgoing: 0x7e 0x01 0x21 0x22 0x23 <0x402>
50 08/14/11 22:30:22.381 luup_log:17: Received good message 0x01 <0x402>
50 08/14/11 22:30:22.383 luup_log:17: Message: Incoming message body: 0x32 0x2e 0x30 0x30 0xf2 0x01 0xfa 0x07 0x00 0xc8 <0x402>
50 08/14/11 22:30:22.383 luup_log:17: Handling message: 0x01 Interface Configuration <0x402>
50 08/14/11 22:30:22.384 luup_log:17: Firmware version 2.00 <0x402>
50 08/14/11 22:30:22.386 luup_log:17: All message codes are supported. <0x402>
50 08/14/11 22:30:22.386 luup_log:17: Zone Name enabled <0x402>
50 08/14/11 22:30:22.387 luup_log:17: Set Clock enabled <0x402>
50 08/14/11 22:30:22.388 luup_log:17: Secondary Keypad Function enabled <0x402>
50 08/14/11 22:30:22.388 luup_log:17: Zone bypass enabled <0x402>
50 08/14/11 22:30:22.389 luup_log:17: Sending message and waiting for response: 0x3b Set Interface Clock <0x402>
50 08/14/11 22:30:22.393 luup_log:17: Message: Outgoing: 0x7e 0x07 0xbb 0x0b 0x08 0x0e 0x16 0x1e 0x01 0x19 0x7c <0x402>
50 08/14/11 22:30:22.851 luup_log:17: Received good message 0x1d <0x402>
50 08/14/11 22:30:22.852 luup_log:17: Message: Incoming message body: <0x402>
50 08/14/11 22:30:22.852 luup_log:17: Sending message and waiting for response: 0x28 System Status Request <0x402>
50 08/14/11 22:30:22.854 luup_log:17: Message: Outgoing: 0x7e 0x01 0x28 0x29 0x2a <0x402>
50 08/14/11 22:30:23.011 luup_log:17: Received good message 0x08 <0x402>
50 08/14/11 22:30:23.013 luup_log:17: Message: Incoming message body: 0x0c 0x00 0x00 0x00 0x00 0x82 0x00 0x00 0x00 0x01 0xb3 <0x402>
50 08/14/11 22:30:23.014 luup_log:17: Handling message: 0x08 System Status <0x402>
50 08/14/11 22:30:23.014 luup_log:17: Valid partition 1 <0x402>
50 08/14/11 22:30:23.015 luup_log:17: PIN length is 4 <0x402>
50 08/14/11 22:30:23.018 luup_log:17: Getting zone name for 1 <0x402>
50 08/14/11 22:30:23.018 luup_log:17: Sending message and waiting for response: 0x23 Zone Name Request <0x402>
50 08/14/11 22:30:23.021 luup_log:17: Message: Outgoing: 0x7e 0x02 0x23 0x00 0x25 0x4c <0x402>
50 08/14/11 22:30:23.191 luup_log:17: Received inconvenient message 0x08 <0x402>
50 08/14/11 22:30:23.193 luup_log:17: Message: Unsolicited message body: 0x0c 0x00 0x00 0x00 0x00 0x82 0x00 0x00 0x00 0x01 0xb4 <0x402>
50 08/14/11 22:30:23.194 luup_log:17: Sending message: 0x1D Positive Acknowledge <0x402>
50 08/14/11 22:30:23.195 luup_log:17: Message: Outgoing: 0x7e 0x01 0x1d 0x1e 0x1f <0x402>
50 08/14/11 22:30:23.198 luup_log:17: Message: Outgoing: 0x7e 0x02 0x23 0x00 0x25 0x4c <0x402>
50 08/14/11 22:30:23.351 luup_log:17: Received inconvenient message 0x08 <0x402>
50 08/14/11 22:30:23.353 luup_log:17: Message: Unsolicited message body: 0x0c 0x00 0x00 0x00 0x00 0x82 0x00 0x00 0x00 0x01 0xb4 <0x402>
50 08/14/11 22:30:23.353 luup_log:17: Sending message: 0x1D Positive Acknowledge <0x402>
50 08/14/11 22:30:23.354 luup_log:17: Message: Outgoing: 0x7e 0x01 0x1d 0x1e 0x1f <0x402>
50 08/14/11 22:30:23.357 luup_log:17: Message: Outgoing: 0x7e 0x02 0x23 0x00 0x25 0x4c <0x402>
50 08/14/11 22:30:23.401 luup_log:17: Received inconvenient message 0x1e <0x402>
50 08/14/11 22:30:23.402 luup_log:17: Message: Unsolicited message body: <0x402>
50 08/14/11 22:30:23.403 luup_log:17: Message: Outgoing: 0x7e 0x02 0x23 0x00 0x25 0x4c <0x402>
50 08/14/11 22:30:23.451 luup_log:17: Received inconvenient message 0x1e <0x402>
50 08/14/11 22:30:23.452 luup_log:17: Message: Unsolicited message body: <0x402>
50 08/14/11 22:30:23.454 luup_log:17: Message: Outgoing: 0x7e 0x02 0x23 0x00 0x25 0x4c <0x402>
50 08/14/11 22:30:23.501 luup_log:17: Received inconvenient message 0x1e <0x402>
50 08/14/11 22:30:23.502 luup_log:17: Message: Unsolicited message body: <0x402>
this last bit just repeats itself. Any help would be appreciated!
