I am trying to sort the rooms new but it appears that Veramate is showing them in order of creation on the VeraLite. Anyway I can re-order them? I tried with renaming them starting with numbers 1…7 but this won’t change the order at all…
Long press on the room icon and it will start shaking you’ll enter the page setup mode. You can then drag the rooms to whatever order you want them. By tapping on them you can change names, icons, ect.
