I have 2 RCS serial thermostats and they work perfectly with Homseer using a serial to USB adapter and HS plug-in. Can they be used with Mi Casa Verda? Thanks
Hi njbillt,
Looks like no, at least not out of the box.
However, it appears that RCS publishes the protocol, so it should be possible for you (if you are programmer-minded) to create the necessary plugin.
