Hello to all. I’m new in the forum and I wish to buy a good z-wave controller.
The first use will be to control home heating.
I’m still benchmarking MCV Vera3 and HC2:
Main pros for HC" seems to be:
- Simplicity in accomplishing the “normal” tasks,
 - HW aesthetic
 - GUI aesthetic.
 - GPS user localization (and, if I understand correctly, the ability to do task in function of the user distance from home)
The pro for MCV Vera3 seems to be:
- the fact you can write code to do anything, (but it seems in despite of ease of use…)
 - WI-FI (I haven’t decided yet where to place the control center…)
 - more compatibility with Z-wave device (accordingly to this page: http://www.vesternet.com/...e#.UmaHnRaUhFg)
Any suggestion to complete the banchmark will be appreciated even if I think there is some thread about this somewhere in the forum.
But at the moment I have some technical question.
Please forgive me if the question is trivial, but I’m a novice.
Now I have a gas heater with one unique zone and a thermostat in the living room.
I would like to install 12 radiator valves and setup 7-9 zones.
I would like to setup the controller for a hourly/weekly program with the desired temp for each zone, for each hour/day of the week.
Then I would like the controller could send every single program to each valve. I would like the valves has an own temp sensor and once they get the program from the controller they are able to open or close according to the program and the actual temp.
(It can be done either with weekly programmable radiator valves or by sending a new setpoint to the valve fron the controller when needed).
I would like to see from the controller GUI, and for each zone:
the programmed temp
the actual temp
the valve state
And, last wish, I would like to program the controller in manner that, when all the valves are closed, the controller could open a switch for stopping the heater (using the thermostat input of the heater).
I was looking to the Danfoss Living Connect, but they do not report the temp neither their status to the controller, so I cant read the state, the read temp, and I cant stop the heater.
Are there other Z-wave radiator valve that can report to the controller the read temp end their status?
If yes, will be possible to set up an OR statement in Vera 3 that will open a switch (like SSR303, or a cheaper one) when all valves are closed?
Thank you very much for your help!
Bye
Mauro.
