Quickview reference : time lag problem?
Hi Chris,
I’ve a lag of 2 hours between graphs visualized directly through dataMine and the same graphs called through their Quickview references.
Vera 3 - UI5 1.5.622
dataMine version : 0.980 (LUA and GUI)
localization : France
Hello,
I have the same problem and also in France.
Even with good local time in graph settings, the quickview remains with international time.
Did you find the solution ?
Patrice
Hi Patrice,
No, and after some tests, things are getting worst : I’m now unable to keep the option “Display local time” at “true” ; it comes back at “false” every time I close datamine.
[right][/right]Thank LG for your reply
Chris, please help…
Known problem which will be fixed on next release or not ?
When ?
Thanks a lot
Patrice
