1.Is it possible to control the Vera edge by sending commands from the command prompt in windows (cmd)? For instance switching lights on and off?
2.I have I Qubino Flush dimmer. Is it possible to control a scene in the Vera by changing wall switch nr 2 (I2) on the Qubino. Wall switch nr 1 will change the state of a local lamp and I want switch nr 2 to send a signal (communicate) to the Vera.
3.Is it possible to program the Vera to send a call request to my server when a lamp changes status. When I use the Vera-app to control a lamp I want the Vera to send a http/UDP signal to my server. Is that possible to configure?
You can send HTTP commands from a browser to control Vera devices. See Luup Requests. You could probably send these from the command line using a program like Wget for Windows.
I believe the I2 input on Qubino devices is shown as a motion sensor on Vera. You should be able to trigger scenes when this is tripped.
You can use the Lua function luup.inet.wget() to send an HTTP request from a scene that is triggered when your lamps change state. See Wget. You could also use the Lua Socket library to send UDP datagrams but that requires a little more code.
