I have U-verse TV, Voip, and internet, & wireless access using U-verse router. I want to continue to use existing U-verse router for everything “EXCEPT” wireless. It is 802.11 G and not “N” so I want the faster speed. I AM GOING TO TURN OFF THE WIRELESS 802.11 G CAPABILITIES ON U-verse router. I have been researching what I knew as access points in the past to use as the only wireless access to my existing network. I would use Ethernet patch cable from existing U-verse router Lan port to the new device that will supply the wireless N capabilities. I have put 2 routers on same network before and have had trouble because the Lan traffic wanted to go out through the WAN port. In my research I have found that instead of access points there are routers that have user friendly settings to bypass the Lan to Wan routing and act as an access point and take Wireless traffic then pass it off to your existing LAN just like if you added a cat5 wired Ethernet switch to your network to add multiple devices in another room. Now that switch in cheaper switches doesn’t get an ip address so isn’t accessible for any GUI type programming like a Router would be. So what I want to know is can the Vera3 be patched in with Ethernet to my existing network only to function as my Z-wave to Ethernet converter and my sole wireless N access thus passing traffic to U-verse gateway for the dhcp, routing, and Wan access? “AND !!!” then be able to assign the Vera3 it’s own ip address on the same network so I can access it’s GUI to program and view Z-wave device interface to manage. I can forward a port from my existing router to get traffic from the WAN onto my LAN and to the assigned ip address for the Vera 3 to manage it remotely like I do my server now if this is possible. Can this be done? Also it is not clear to me why micasaverde has a server that they want you to go through to be able to reach your unit. I have my own domain name and dyndns type program that keeps my WAN ip address updated so I can always get to my router remotely from internet.
No. Don’t. Really, don’t. There is no authentication if you port-forward, so anyone who can guess your IP address and port will be able to control your Vera.
The mios.com servers provide that authentication layer. If you want to bypass mios.com them you needed to provide your own authentication mechanism. VPN is one way which had been talked about on the forum already.
Read the many prior discussions about this in the Security section of the forum.
